Cover the basics with our straightforward wireless security camera.
Home security you can control from your smartphone. 100% wire-free and weather resistant, install in minutes for no-fuss protection.
6 month battery life
Wire-free, no cords or wiring hassles
Capture clear details in full high definition
Record video in 1080p, and see more of the picture with a 130° viewing angle.
Weather Resistant
Withstands heat, cold, rain or sun
Motion detection alerts
Take quick action and view live video, sound the siren, or call a friend directly from your phone.
See in colour, even at night
Ward off intruders and view unique details in colour with the integrated spotlight.
Simple installation
Set up your camera in a few easy steps thanks to its 100% wireless design. Connect directly to wifi - no base station required.
2-way audio
Hear and speak to visitors in real time with high quality audio via the Arlo app or using your smart assistant.
Deter intruders with built-in siren
Set the siren to sound automatically during an event or trigger it remotely from the app.
Connect and control with your favourite smart assistant
Works with Amazon Alexa, Google Assistant and IFTTT.
Weather-resistant security
Arlo Essential is designed to withstand heat, cold, rain, and sun. -
Ward off intruders and view unique details in colour with the integrated spotlight. -
Quickly install
Set your wire-free camera in just a few easy steps. -
Trigger your siren automatically, or manually from your phone. -
Get alerts when motion is detected
- Arlo Essential - network surveillance camera
- Network surveillance camera - fixed - indoor, outdoor - weatherproof
- Packaged Quantity
- 3 (specifications are for single item)
- Audio
- Yes: two-way audio capability, built-in microphone, built-in speaker
- Camera Mount Type
- Wall mount
- 5.2 cm x 7.84 cm x 8.9 cm
- 331 g
- White
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Optical Sensor Type
- CMOS
- Wi-Fi
- Intelligent Assistant
- Alexa, Google Assistant
- Built-in spotlight, e-mail alerts, 110-degree motion detection angle, echo reduction, built-in siren, noise-cancellation
- 1-year warranty
- Environmental Parameters (operating)
- -20 °C - 45 °C
- Packaged Quantity
- Audio Support
- Camera Mount Type
- Wall mount
- Wireless
- 5.2 cm
- 7.84 cm
- 8.9 cm
- 331 g
- Localisation
- Europe
Camera
- Colour - Day&Night - fixed - indoor, outdoor - weatherproof
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Digital Zoom
- 12
- Infrared LEDs
- Infrared Distance
- 7.62 m
- Digital Video Capture Resolution
- 1920 x 1080
Image Sensor
- CMOS
Lens Construction
- Diagonal Field of View (degree)
- 130
- Network Interface
- Wi-Fi
- Included Accessories
- Wall mount kit
- FCC, IC
- White
- Software Included
- Arlo Smart (3-months trial)
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Limited warranty - 1 year
- -20 °C
- 45 °C
