For pros who use a VESA stand, mount, or arm instead of a traditional stand, the VESA Mount Adapter is the perfect way to seamlessly add Pro Display XDR to your workspace. It works with any VESA-compatible 100 by 100 mm wall mount, desk mount, stand, or articulating arm that can support the 16.49-pound (7.48 kg) Pro Display XDR. And it can be placed and secured quickly and easily using the included Apple-designed lock key.
Legal
¹The VESA Mount Adapter has 8 mm of available thread. Verify that the mounting plate thickness and screw length will enable the screw to fully fasten.
- Apple VESA Mount Adapter mounting component - for Monitor
- Product Type
- Mounting component
- Mounting Components
- VESA mount bracket
- 11.9 cm x 1.83 cm x 11.9 cm
- 280 g
- Recommended Use
- Monitor
- VESA Mounting Interface
- 100 x 100 mm
- Package Content
- Apple-designed lock key
- Designed For
- Pro Display XDR
- 11.9 cm
- 1.83 cm
- 11.9 cm
- 280 g
- Package Content
AV Furniture
- Recommended Use
- Monitor
- 100 x 100 mm
- Designed For
- Apple Pro Display XDR
