Place a display, up to 30" in size, at your desk, using this height-adjustable monitor mount with integrated cable management. The adjustable monitor stand lets you mount a display on your desk, with tilt, pivot and height adjustments for perfect positioning. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
The monitor stand holds most common displays with ease, supporting monitors from 12 - 30" up to a maximum weight capacity of 30lbs (14kg). For added flexibility, the included hardware can be used to mount your Apple iMac or Apple Cinema Display.
The desktop monitor stand features a 15in (380mm) tall support post, for a much greater range of height adjustments than typical monitor stands can provide. For viewing longer pages or blocks of code without scrolling, the LCD stand also supports landscape to portrait display rotation.
Adjust your display height, position and viewing angles easily to create an ergonomic work environment, with the added benefit of reclaiming valuable workspace on your desk by mounting on a support post above the desk surface.
Versatile display support
This monitor stand accommodates displays from 12 inches to 34 inches, suitable for a wide range of devices. -
Adjustable height functionality
Easily adjust the height of the monitor stand to achieve a comfortable viewing level, reducing neck strain over time. -
Flexible positioning options
The stand allows for tilt adjustments ranging from -15° to 45° along with a 60° swivel, providing customization for your ideal screen angle. -
Integrated cable management
Keep your workspace organized with built-in cable management that tidily routes and stores cables, preventing clutter. -
Sturdy construction
Crafted with durable steel, this monitor stand supports a maximum load of 14 kg, ensuring stability and reliability for your display.
- StarTech.com Single Monitor Stand - Adjustable - Supports Monitors 12" to 34" - Premium - Single Screen VESA Monitor Mount Stand - Silver (ARMPIVSTND) mounting kit - for LCD display - silver
- Product Type
- Mounting kit
- Mounting Components
- Desk stand, feet, wrench, screws, cable clip
- 33 cm x 26 cm x 10.5 cm
- Tilt
- -15° to 45°
- Swivel
- 60°
- Adjustments
- Pan, tilt
- 2.4 kg
- Recommended Use
- LCD display
- Recommended Display Size
- 12"-34"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 14 kg
- Material
- Plastic, steel
- Silver
- 5-year warranty
- 33 cm
- 26 cm
- 10.5 cm
- 2.4 kg
- Material
- Plastic, steel
- Silver
AV Furniture
- Mounting kit
- Recommended Use
- LCD display
- Cable Management
- Integrated cable management
- 12"-34"
- Tilt
- -15° to 45°
- Swivel
- 60°
- Adjustments
- Pan, tilt
- Max Load Weight
- 14 kg
- Adjustable height, portrait to landscape movement, swivel adjustment, pivot
- Limited warranty - 5 years
StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 | In Stock | £57.25 |
StarTech.com Height Adjustable Monitor Arm - Grommet / Desk Mount with Cable Hook | In Stock | £64.93 |
StarTech.com Desktop Monitor Stand with Cable Hook - Mounting Kit | In Stock | £91.99 |
StarTech.com Articulating Monitor Arm | In Stock | £121.96 |
StarTech.com Sit-to-Stand Workstation | In Stock | £124.29 |
StarTech.com Monitor and Laptop Arm | In Stock | £114.13 |
StarTech.com USB-C Multifunction Adapter | In Stock | £47.42 |
StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 | In Stock | £70.33 |
StarTech.com Thin Client Mount - VESA | In Stock | £23.04 |
StarTech.com Under Desk Keyboard Tray | In Stock | £53.36 |
StarTech.com Desk Mount Monitor Arm | In Stock | £60.75 |
StarTech.com Crossbar Dual Monitor Stand | In Stock | £86.32 |
StarTech.com Dual Monitor Vertical Mount | In Stock | £121.00 |
