Apple Pro Stand for Pro Display XDR
Quicklinx: FKXYWS00 Mfr#: MWUG2Z/A
Accessory Type: Stand
£777.27 ex VAT
£932.72 inc VAT
Every aspect of Pro Stand was designed with pros in mind. Height, tilt, rotation - it's completely adjustable, allowing your Pro Display XDR to fit seamlessly into any work environment.
  • Height adjustment and tilt
    With precision tilting and 120mm of total height adjustment, Pro Stand helps Pro Display XDR adapt to any viewing condition. When you adjust the height, the angle of the display stays true. Thanks to a highly sophisticated mechanism in the arm, the display feels weightless, moves effortlessly and stays exactly where you want it.
  • Rotation
    Pro Stand gives you the ability to easily transition between landscape and portrait whenever you want. Change the screen's orientation by simply unlocking the slider and turning the display anticlockwise. This flexibility allows the display to quickly adapt to a pro's changing content.
Apple Pro Stand stand - for Monitor
Stand - desktop
18 cm x 23.6 cm x 49.7 cm
Tilt
-5° to 20°
Adjustments
4.3 kg
Recommended Use
Monitor
Pro Display XDR
18 cm
23.6 cm
49.7 cm
4.3 kg
AV Furniture
Stand
Recommended Use
Monitor
Placing / Mounting
Desktop
Tilt
-5° to 20°
Adjustments
Apple Pro Display XDR
Brand: Apple
Price Range Ex VAT: £750 - £1000
