Apple Lightning to USB 3 Camera Adapter
Quicklinx: CCS8WS00 Mfr#: MK0W2ZM/A
With the Lightning to USB 3 Camera Adapter, it's easy to transfer photos and videos from your high-resolution digital camera to your iPad. Add even greater capability and versatility to your iPad by powering the Lightning to USB 3 Camera Adapter with USB power adapter. Then you can connect USB peripherals like hubs, Ethernet adapters, audio/MIDI interfaces, and card readers for CompactFlash, SD, microSD and more. The Lightning to USB 3 Camera Adapter supports standard photo formats.
  • Versatile connectivity
    The Apple Lightning to USB 3 Camera Adapter offers a seamless connection between your Apple devices and USB peripherals. With both Lightning and USB interfaces, it supports a wide range of accessories from cameras to keyboards, making your devices more versatile.
  • High-quality design
    Crafted with precision and quality, this adapter ensures a reliable connection between your devices. Its durable build is designed to withstand daily use, making it an essential accessory for your Apple ecosystem.
Apple Lightning to USB 3 Camera Adapter - Lightning adapter - Lightning / USB
Cable
Connectors
Lightning - male
Connectors (Second End)
USB - female , Lightning - female
Cable Type
Lightning adapter
Interface Supported
Lightning / USB
Connectors
Apple Lightning - male
4 pin USB Type A - female , Apple Lightning - female
