APC NetShelter SX Enclosure with Sides - Rack - black - 42U - 19"
Quicklinx: 4FC8WS00 Mfr#: AR3150
Depth (mm): 107cm
Type: Floor standing
U Height: 42U
Width (mm): 75cm
£1,719.89 ex VAT
£2,063.86 inc VAT
APC sets the standard in its industry for quality, innovation and support. Its comprehensive solutions, which are designed for both home and corporate environments, improve the manageability, availability and performance of sensitive electronic, network, communications and industrial equipment of all sizes. The mission of APC is to improve the manageability, availability, and performance of information and communication systems through rapid development and delivery of innovative solutions to real customer problems.
APC NetShelter SX Enclosure with Sides - rack - 42U
Rack
Height (Rack Units)
42U
75 cm x 107 cm x 199 cm
156 kg
Rack
Height (Rack Units)
42U
75 cm
107 cm
199 cm
156 kg
Weight Limit
1361 kg
BAA
TAA Compliant
4FC8 APC Basic Rack-Mount PDU - power distribution strip In Stock £204.64
4FC8 APC 1U Vertical Cable Organiser In Stock £124.80
4FC8 APC 1U Horizontal Cable Organiser In Stock £55.47
4FC8 APC Smart-UPS SC 450VA 1U In Stock £279.98
4FC8 APC Netshelter heavy duty shelf In Stock £141.95
4FC8 APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT In Stock £208.46
4FC8 APC Rack PDU Basic Zero U 16A 208/230V In Stock £302.47
4FC8 APC Smart-UPS 5000VA In Stock £3,661.99
4FC8 APC Rack PDU Basic Zero U 32A 230V In Stock £326.06
4FC8 APC Smart-UPS RT 20kVA RM 230V In Stock £12,172.54
4FC8 APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £289.09
4FC8 APC Smart-UPS X 1500VA Rack/Tower LCD 230V In Stock £1,186.69
4FC8 APC Cable Managers (Qty 10) In Stock £36.38
4FC8 APC 2G Power distribution strip In Stock £649.15
4FC8 APC Rack PDU 2G METERED ZEROU In Stock £687.91
4FC8 APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V In Stock £2,317.04
4FC8 APC 1U 19" Black Modular Toolless Blanking Panel - Qty 200 In Stock £511.74
4FC8 APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V w/ Network Card In Stock £2,667.34
4FC8 APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £1,000.76
4FC8 APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £959.96
4FC8 APC 19" Rack LCD Console In Stock £1,370.27
4FC8 APC Vertical Cable Organizer, NetShelter SX, 42U In Stock £94.52
4FC8 APC Fixed Shelf - 50lbs/23kg, Black In Stock £80.88
4FC8 APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,510.33
4FC8 APC NetShelter Zero U Accessory Mounting Bracket In Stock £99.01
4FC8 APC Smart-UPS X 2200VA Rack/Tower LCD 200-240V - 4U In Stock £1,457.00
4FC8 APC Smart-UPS X 3000 Rack/Tower LCD 2700 Watt 3000 VA In Stock £1,932.90
4FC8 APC 1U Blanking Panel Kit In Stock £34.80
4FC8 APC Smart-UPS 1500VA LCD RM 1U 230V In Stock £975.47
4FC8 APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £55.94
4FC8 APC Smart-UPS SRT 6000VA RM 230V In Stock £4,787.01
4FC8 APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.98
4FC8 APC Smart-UPS SRT 8000VA RM 230V In Stock £6,184.96
4FC8 APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,642.73
4FC8 APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £69.11
4FC8 APC SMX3000HVNC Smart-UPS X1500VA Rack/Tower LCD230V In Stock £2,389.72
4FC8 APC SMX1500RMI2UNC Smart-UPS 1500VA Rack/Tower LCD 230V with Net In Stock £1,636.88
4FC8 APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £638.53
4FC8 APC Smart-UPS SRT 2200VA RM 230V In Stock £1,801.52
4FC8 APC Smart-UPS SRT 3000VA RM 2700 Watt 3000 VA - Lead Acid In Stock £2,750.54
4FC8 APC Metered Rack PDU In Stock £856.35
4FC8 APC Smart-UPS 1500VA RM 230V w/Network Card In Stock £1,185.53
4FC8 APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U In Stock £265.59
4FC8 APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,097.93
4FC8 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £62.16
4FC8 APC Rack PDU 2G Metered-by-Outlet ZeroU 32A 230V (21) C13+(3)$ In Stock £1,207.93
4FC8 APC Smart-UPS SRT 10000VA RM 230V In Stock £7,502.13
4FC8 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £677.83
4FC8 APC Smart-UPS C 1000VA 2U LCD - UPS (rack-mountable) In Stock £595.90
4FC8 APC Smart-UPS 1000VA LCD RM - UPS (rack-mountable) In Stock £717.17
4FC8 APC Smart-UPS 1500VA LCD RM - UPS (rack-mountable) In Stock £891.35
4FC8 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,261.34
4FC8 APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £163.11
4FC8 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,306.71
4FC8 APC Rack PDU Basic 0U/1U 100-240V/ In Stock £84.13
4FC8 APC Smart UPS 2200VA LCD RM 2U 230 In Stock £1,488.58
4FC8 APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £472.34
4FC8 APC Smart-UPS SRT 3000VA RM Network Card In Stock £3,128.26
4FC8 APC Smart-UPS SMT3000RMI2UC - UPS (rack-mountable) - AC 220/ In Stock £1,932.30
4FC8 APC Smart-UPS 3000VA LCD RM - UPS (Rack-Mountable) AC 230 V In Stock £2,254.08
4FC8 APC Smart-UPS 750VA RM 230V SmartConnect In Stock £525.39
Resources
The following resources are available for the APC NetShelter SX Enclosure with Sides - Rack - black - 42U - 19"
Depth (mm): 107cm
U Height: 42U
Width (mm): 75cm
Brand: APC
Price Range Ex VAT: £1500+
