APC Smart-UPS SC 450VA 1U
Customer rating: 5.0* (Write a review)
Quicklinx: 3W75WS00 Mfr#: SC450RMI1U
Type: UPS
Power Rating: 280watt
More than 50 In Stock
£276.02 ex VAT
£331.22 inc VAT
APC Smart-UPS SC is the perfect protection for the IT resources of your growing business. Manageable and cost effective, APC Smart-UPS SC is designed for use by small and medium companies looking to protect networking equipment, providing both power and data-line protection. Included PowerChute Business Edition management software allows you to configure safe system shutdowns and take advantage of advanced UPS management features like automated risk assessments and runtime capacity calculations. (All major operating systems supported). Communications are through your server's standard serial port. When you are ready to take your business to the next level you can use the same software environment found on Smart-UPS SC to seamlessly manage other Smart-UPS models, allowing you to grow your IT infrastructure without having to replace your software or retrain your administrators. Built on the same standards as the award winning Smart-UPS UPS, the Smart-UPS SC is the UPS to start your business with.
  • Front-access servicing
    Simplifies installation and UPS maintenance while minimizing space requirements
  • Rack/Tower convertible
    Protects the initial investment in the UPS when migrating from tower to rack-mount environment
  • Multiple mounting methods
    Allows for standardization on one product for use in different environments
APC Smart-UPS SC 450VA - UPS - 280 watt - 450 VA
UPS - rack-mountable
Rack Size
1U
10.2 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 5%
Power Capacity
280 watt / 450 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
4 x power IEC 60320 C13
Lead Acid
Battery Form Factor
Plug-in module
Run Time (Up To)
5.9 min at full load
RS-232
Grey
43.2 cm x 38.3 cm x 4.4 cm
P/N: AR106SH6, AR109SH6, AR112SH6, AR3003, AR3003SP, AR3006, AR3006SP, AR3103, AR3103SP, AR3106, AR3106SP, AR3140G, AR3340G, AR3357X674, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A
Battery Enclosure Type
Plug-in module
Height (Rack Units)
1U
Grey
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Provided
47 - 63 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V ± 5% - 47 - 63 Hz
Power Capacity
280 watt / 450 VA
Dataline Surge Protection
Network/phone line - RJ-45/RJ-11
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Surge Energy Rating
320 joules
Lead Acid
Run Time (Up To)
Remote Management Interface
RS-232
1 x management (RS-232) - 9 pin D-Sub (DB-9)
Serial cable - external
Rack Mounting Kit
Included
Audible alarm, LED display
C-Tick, GOST, PCBC, VDE, EN 50091-2
Software Included
APC PowerChute Business Edition
0 - 95%
43.2 cm
38.3 cm
4.4 cm
10.2 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, ACF600, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR100, AR100HD, AR106SH6, AR109SH6, AR112SH6, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3003, AR3003SP, AR3006, AR3006SP, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3103, AR3103SP, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3106, AR3106SP, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3357X674, AR3810, AR3812, AR3814, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
3W75 APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £30.51
3W75 APC Power Cord IEC 320 C19 TO IEC 320 C14 In Stock £50.04
3W75 APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £53.95
3W75 APC Rack PDU, Basic, Zero U, 10A,2 In Stock £279.09
3W75 APC Power Cable (pack of 6) 1.22m In Stock £90.23
3W75 APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £132.53
3W75 APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £104.13
3W75 APC Service Pack 1 Year Warranty Extension In Stock £48.56
3W75 APC Service Pack 3 Year Warranty Extension In Stock £107.26
3W75 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £62.92
3W75 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £689.02
3W75 APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £467.09
Resources
The following resources are available for the APC Smart-UPS SC 450VA 1U
Customer reviews
Write a review for the APC Smart-UPS SC 450VA 1U here!
Q: about noise
Reviewed by boolve. Review Posted 27/01/2008
I have question. Are this UPS build in fan? All rack mount APC UPS with noise level ~ 34dBa. All time this fan is on?
  • Overall 5*
  • Ease of use 5*
  • Value for money 3*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Type: UPS
Brand: APC
