Increases availability by allowing the UPS to be connected to two separate power sources. Reduces preventative maintenance service needs by monitoring the health and status of the external batteries and their expected runtime.
Dual mains input
Increases availability by allowing the UPS to be connected to two separate power sources. -
LCD display
Manage the UPS locally through a text-based display that allows quick diagnosis via stored alarm conditions and events. -
Manageable external batteries
Reduces preventative maintenance service needs by monitoring the health and status of the external batteries and their expected runtime. -
Rack/Tower convertible
Protects the initial investment in the UPS when migrating from tower to rack-mount environment. -
Removable input/output wiring tray
Allows quick and easy installation and maintenance of the UPS. -
Single or three-phase input wireable
Provides flexibility for the UPS to be installed using either single or three-phase input wiring.
- APC Smart-UPS RT - UPS - 16 kW - 20000 VA
- UPS - rack-mountable
- Rack Size
- 12U
- 248 kg
- Input Wiring
- 3-phase / 1-phase
- Input Voltage
- AC 220/230/240 V
- Output Voltage
- AC 220/230/240 V ± 5%
- Power Capacity
- 16 kW / 20000 VA
- Input Connectors
- 1 x hardwire 5-wire (3PH + N + G), hardwire 3-wire (1PH + N + G)
- Output connectors
- 1 x hardwire 3-wire (2PH + G) , 1 x hardwire 5-wire (3PH + N + G) , 8 x power IEC 60320 C19
- Battery
- Lead Acid
- Battery Form Factor
- Plug-in module
- Batteries Qty
- 4
- Run Time (Up To)
- 4.9 min at full load
- Networking
- Ethernet 10/100, RS-232
- Remote Management Protocol
- SNMP, Telnet, HTTP, HTTPS
- Black
- 43.2 cm x 77.3 cm x 53.3 cm
- 2-year warranty
- Designed For
- P/N: AR2200, AR2280, AR2487G, AR3100TAA, AR3100W, AR3105SP, AR3105W, AR3107G, AR3107SP, AR3140G, AR3140W, AR3150SP, AR3150W, AR3155SP, AR3155W, AR3157SP, AR3300G, AR3300SP, AR3300W, AR3305SP, AR3305W, AR3307SP, AR3307W, AR3340G, AR3340W, AR3350SP, AR3350W, AR3355SP, AR3355W, AR3357SP, NBWL0356A
- Battery Enclosure Type
- Plug-in module
- Height (Rack Units)
- 12U
- Black
- UPS Technology
- On-line
- Input Voltage
- AC 220/230/240 V
- Input Voltage Range
- AC 160 - 280 V
- Frequency Provided
- 50/60 Hz
- Input Wiring
- 3-phase / 1-phase
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 220/230/240 V ± 5% - 50/60 Hz
- Power Capacity
- 16 kW / 20000 VA
- Output Waveform
- Sinewave
- Surge Suppression
- Circuit Protection
- Circuit breaker
- Quantity
- 4
- Technology
- Lead Acid
- Voltage Provided
- 192 V
- Run Time (Up To)
- Recharge Time
- 2.5 hours
- Remote Management Interface
- 1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (Ethernet) - RJ-45 , 1 x EPO (emergency power off)
- Expansion Slots
- SmartSlot
- Cables Included
- Serial cable - external
- Rack Mounting Kit
- Included
- Audible alarm, emergency power off, LCD display, built-in static bypass, internal bypass
- UL 1449, VDE, IEC 62040-1-1
- Software Included
- APC PowerChute Business Edition
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 59 dBA
- 43.2 cm
- 77.3 cm
- 53.3 cm
- 248 kg
- Shipping Width
- 61 cm
- Shipping Depth
- 100 cm
- Shipping Height
- 99 cm
- Shipping Weight
- 314 kg
- Designed For
- P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
APC - Power cable - Male-Female - 1.98 m | In Stock | £49.54 |
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £206.71 |
APC 1U Vertical Cable Organiser | In Stock | £124.89 |
APC 1U Horizontal Cable Organiser | In Stock | £56.02 |
APC Pwr Cord, 16A, 200-240V, C19 to UK Plug | In Stock | £60.23 |
APC Netshelter heavy duty shelf | In Stock | £143.64 |
APC Power cable - 2.4 m | In Stock | £86.53 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £306.09 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £333.11 |
APC Temperature and Humidity Sensor | In Stock | £131.59 |
APC POWER CORD C13 TO C20 1.98m Black | In Stock | £53.59 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £298.45 |
APC Cable Managers (Qty 10) | In Stock | £36.74 |
APC 2G Power distribution strip | In Stock | £656.08 |
APC Rack PDU 2G METERED ZEROU | In Stock | £700.76 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 200 | In Stock | £520.88 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £1,010.57 |
APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & | In Stock | £969.36 |
APC Power Cord Locking C19 to IEC309-16A 3.0m | In Stock | £86.39 |
APC Vertical Cable Organizer, NetShelter SX, 42U | In Stock | £96.20 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £81.84 |
APC Power Cord Kit (6 ea) Locking C19 to C20 1.2m | In Stock | £153.08 |
APC Power Cord, C19 to CEE/7 Schuko, 2.5m | In Stock | £55.24 |
APC Switched Rack PDU 2G Zero U Power Distribution Unit | In Stock | £1,491.34 |
APC NetShelter Zero U Accessory Mounting Bracket | In Stock | £99.34 |
APC 1U Blanking Panel Kit | In Stock | £35.14 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £56.79 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £48.54 |
APC Rack PDU 2G Metered ZeroU 22.0kW | In Stock | £1,706.21 |
APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided | In Stock | £69.80 |
APC Replacement Battery Cartridge #140 - UPS battery - Lead Acid - 960 Wh | In Stock | £589.12 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £644.79 |
APC Metered Rack PDU | In Stock | £855.55 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £772.11 |
APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U | In Stock | £269.76 |
APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,108.69 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £62.78 |
APC Rack PDU 2G Metered-by-Outlet ZeroU 32A 230V (21) C13+(3)$ | In Stock | £1,220.80 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £685.93 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,276.44 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £164.97 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 | In Stock | £1,319.52 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £84.20 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £462.84 |
