APC NetShelter SX 42U 750mm Wide x 1070mm Deep Networking Enclos
Quicklinx: 86CRWS00 Mfr#: AR3140
Type: Floor standing
U Height: 42U
Depth (mm): 107cm
Width (mm): 75cm
Hurry, only 1 left in stock!
£2,232.58 ex VAT
£2,679.09 inc VAT
NetShelter SX networking enclosure expands APC's superior IT enclosure line with improved support for high density networking applications. Integrated high density cable managers and improved cable access roof provide support for large cable bundles. When combined with the side airflow duct kit, the networking enclosure ensures complete isolation of cold intake and hot exhaust air for large switches and SAN directors.
  • Integrated high density cable management
    Decrease installation time while supporting the cabling needs of large networking switches.
  • Cable protection and pass-through
    Smooth plastic fingers provide proper bend radius.
  • Improved cable access
    Maintain and organize large cable bundles for improved efficiency with open vertical mounting rails and large cable openings in roof.
  • High density cable management
    The vertical mounting rails are opened up for increased cable access and the roof design has large open areas for cable entry/exit from the enclosure.
  • Optimized enclosure design for side-to-side airflow
    Airflow management panels, left vertical mounting rail, and side airflow duct kit ensure proper side-to-side airflow to the networking switches from the cold aisle and provide isolation of hot air preventing it from re-entering the cold aisle. Additionally, the front left vertical mounting rail acts as an air block for exhaust air from networking switches.
APC NetShelter SX Networking Enclosure with Sides - rack - 42U
Rack
Height (Rack Units)
42U
75 cm x 107 cm x 199 cm
156 kg
5-year warranty
P/N: SUA1000RMI2U, SUA2200RMXLI3U, SUA5000RMI5U
Rack
Height (Rack Units)
42U
75 cm
107 cm
199 cm
156 kg
Weight Limit
1363 kg
Mounting Kit
Included
EIA-310-E, RoHS, UL 60950-1, BAA
TAA Compliant
Limited warranty: - 5 years
86CR APC Basic Rack-Mount PDU - power distribution strip In Stock £200.45
86CR APC 1U Vertical Cable Organiser In Stock £121.77
86CR APC 1U Horizontal Cable Organiser In Stock £53.89
86CR APC Smart-UPS SC 450VA 1U In Stock £281.43
86CR APC - rack cable guide - 1U In Stock £50.85
86CR APC Rackmount Rail Kit In Stock £90.24
86CR APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT In Stock £204.87
86CR APC Rack PDU Basic Zero U 16A 208/230V In Stock £294.43
86CR APC Rack PDU Basic Zero U 32A 230V In Stock £321.56
86CR APC Smart-UPS RT 20kVA RM 230V In Stock £12,150.73
86CR APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £286.39
86CR APC Smart-UPS X 1500VA Rack/Tower LCD 230V In Stock £1,182.34
86CR APC Cable Managers (Qty 10) In Stock £35.06
86CR APC 2G Power distribution strip In Stock £643.24
86CR APC Rack PDU 2G METERED ZEROU In Stock £684.31
86CR APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V In Stock £2,350.82
86CR APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V w/ Network Card In Stock £2,660.28
86CR APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £977.00
86CR APC 19" Rack LCD Console In Stock £1,379.32
86CR APC Fixed Shelf - 50lbs/23kg, Black In Stock £80.83
86CR APC NetShelter Zero U Accessory Mounting Bracket In Stock £65.98
86CR APC Smart-UPS X 2200VA Rack/Tower LCD 200-240V - 4U In Stock £1,468.97
86CR APC Smart-UPS X 3000 Rack/Tower LCD 2700 Watt 3000 VA In Stock £1,923.53
86CR APC 1U Blanking Panel Kit In Stock £34.11
86CR APC Smart-UPS 1500VA LCD RM 1U 230V In Stock £967.82
86CR APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £55.88
86CR APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £47.91
86CR APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £68.98
86CR APC SMX3000HVNC Smart-UPS X1500VA Rack/Tower LCD230V In Stock £2,384.39
86CR APC SMX1500RMI2UNC Smart-UPS 1500VA Rack/Tower LCD 230V with Net In Stock £1,625.73
86CR APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £634.07
86CR APC Smart-UPS SRT 2200VA RM 230V In Stock £1,800.98
86CR APC Smart-UPS SRT 3000VA RM 2700 Watt 3000 VA - Lead Acid In Stock £2,798.21
86CR APC Metered Rack PDU In Stock £842.70
86CR APC Smart-UPS 1500VA RM 230V w/Network Card In Stock £1,192.91
86CR APC Switched Rack PDU AC 208-230 V Ethernet In Stock £743.33
86CR APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U In Stock £263.52
86CR APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £61.02
86CR APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £665.61
86CR APC Smart-UPS C 1000VA 2U LCD - UPS (rack-mountable) In Stock £600.38
86CR APC Smart-UPS 1000VA LCD RM - UPS (rack-mountable) In Stock £716.91
86CR APC Smart-UPS 1500VA LCD RM - UPS (rack-mountable) In Stock £889.42
86CR APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,252.46
86CR APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £158.19
86CR APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,277.16
86CR APC Rack PDU Basic 0U/1U 100-240V/ In Stock £82.71
86CR APC Smart UPS 2200VA LCD RM 2U 230 In Stock £1,515.82
86CR APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £468.04
86CR APC Smart-UPS SRT 3000VA RM Network Card In Stock £3,182.17
86CR APC Smart-UPS SMT3000RMI2UC - UPS (rack-mountable) - AC 220/ In Stock £1,926.60
86CR APC Smart-UPS 3000VA LCD RM - UPS (Rack-Mountable) AC 230 V In Stock £2,271.10
86CR APC Smart-UPS 750VA RM 230V SmartConnect In Stock £527.30
U Height: 42U
Depth (mm): 107cm
Width (mm): 75cm
Brand: APC
Price Range Ex VAT: £1500+
