APC Smart-UPS X 3000 Rack/Tower LCD 2700 Watt 3000 VA
Quicklinx: 9FVFWS00 Mfr#: smx3000hv
Type: UPS
Power Rating: 2700Watt
20 In Stock
£1,926.97 ex VAT
£2,312.36 inc VAT
APC award-winning Smart-UPS is the most popular UPS in the world for servers, storage and network power protection. Trusted to protect critical data and equipment from power problems by supplying clean and reliable network-grade power. In addition to legendary reliability and manageability, Smart-UPS have extremely high efficiency at low, medium and high load levels making them ideal for today's multi-core or virtualized servers that have varying load consumption. Smart-UPS feature a 16-segment LED display, extended range automatic voltage regulation (AVR), and pure sine wave output on battery.
  • Intelligent battery management
    Maximizes battery performance, life, and reliability through intelligent, precision charging
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics
  • Cold-start capable
    Provides temporary battery power when the utility power is out
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection
  • High online efficiency
    Reduces utility costs, generates less heat
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning
  • SmartSlot
    Customize UPS capabilities with management cards
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users
  • Scalable runtime
    Allows additional run time to be quickly added as needed
  • Auto recognition of external batteries
    UPS recognizes when external battery packs are attached and automatically adjusts runtime
  • Rack/Tower convertible
    Protects the initial investment in the UPS when migrating from tower to rack-mount environment
  • Multiple switched outlet groups
    Multiple outlet groups that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding
  • High frequency design
    Reduces or eliminates bulky transformers resulting in lighter units for ease of handling
  • StruxureWare Data Center Expert Compatibility
    Discover and monitor PowerChute Agents via SNMP v1 or v3. Integrate SNMP Traps for timely notifications of UPS critical events
  • Sequenced shutdown and reboot
    Customize shutdown and reboot sequence of connected servers and UPSs
APC Smart-UPS X 3000 Rack/Tower LCD - UPS - 2700 Watt - 3000 VA
UPS - rack-mountable / external
Rack Size
4U
38.64 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
2700 Watt / 3000 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
8 x power IEC 60320 C13 , 2 x IEC jumper , 2 x power IEC 60320 C19
Lead Acid
Batteries Qty
1
Run Time (Up To)
6.3 min at full load
RS-232, USB
17.8 cm x 48.3 cm x 43.2 cm
3-year warranty
P/N: AR2487G, AR3105W, AR3140G, AR3155W, AR3305W, AR3340G, AR3355SP, AR3355W, AR4000MVX429, AR4000MVX432, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A, SMX2000LVUS, SRT1500RMXLA-NC
Height (Rack Units)
4U
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 140 - 280 V
Frequency Provided
47 - 63 Hz
Frequency Required
47 - 63 Hz
Input Connectors
Output Voltage
AC 230 V 47 - 63 Hz
Power Capacity
2700 Watt / 3000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
645 Joules
Circuit Protection
Circuit breaker
Efficiency
98.5%
Quantity
1
Lead Acid
Run Time (Up To)
6.3 min at full load , 15.7 min at half load
Recharge Time
3 hours
Remote Management Interface
RS-232, USB
1 x USB , 1 x RS-232 , 1 x EPO (emergency power off)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Serial cable , USB cable , Power cable 1.83 m
Rack Mounting Kit
Included
Audible alarm, LCD display, overload protection
CSA, C-Tick, GOST, UL 1449, UL 1778, VDE, IEC 60950, EN 50091-2, IRAM, RoHS, EN 50091-1, FCC Part 15 A, REACH
Software Included
APC PowerChute Business Edition
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
55 dBA
17.8 cm
48.3 cm
43.2 cm
38.64 kg
Shipping Width
58.6 cm
Shipping Depth
63.3 cm
Shipping Height
33 cm
Shipping Weight
47.73 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC2513, ACF001, ACF002, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR202, AR203A, AR204A, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3810, AR3812, AR3814, AR4000MV, AR4000MVX429, AR4000MVX432, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A, SMX2000LVNC, SMX2000LVUS, SRT1500RMXLA-NC, SU2200R3X167
9FVF APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £30.83
9FVF APC Power Cord IEC 320 C19 TO IEC 320 C14 In Stock £50.78
9FVF APC - Power cable - Male-Female - 1.98 m In Stock £50.45
9FVF APC Basic Rack-Mount PDU - power distribution strip In Stock £203.03
9FVF APC 1U Vertical Cable Organiser In Stock £125.78
9FVF APC 1U Horizontal Cable Organiser In Stock £55.57
9FVF APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £53.28
9FVF APC Netshelter heavy duty shelf In Stock £141.58
9FVF APC - rack cable guide - 1U In Stock £52.53
9FVF APC Rackmount Rail Kit In Stock £91.35
9FVF APC Power cable - 2.4 m In Stock £85.15
9FVF APC Rack PDU Basic Zero U 16A 208/230V In Stock £295.63
9FVF APC 2-Post Mounting Kit for Smart-UPS In Stock £173.93
9FVF APC 3Yr Extended Warranty SP In Stock £323.27
9FVF APC Rack PDU Basic Zero U 32A 230V In Stock £330.18
9FVF APC Temperature and Humidity Sensor In Stock £132.56
9FVF APC Cable Managers (Qty 10) In Stock £36.99
9FVF APC 2G Power distribution strip In Stock £640.07
9FVF APC APC POWERCORD C19 TO C20 1.8M In Stock £189.39
9FVF APC Rack PDU 2G METERED ZEROU In Stock £693.12
9FVF APC 1U 19" Black Modular Toolless Blanking Panel - Qty 200 In Stock £504.42
9FVF APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £990.67
9FVF APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £976.20
9FVF APC Power Cord Locking C19 to IEC309-16A 3.0m In Stock £84.61
9FVF APC Power Cord Locking C19 to C20 3.0m In Stock £69.88
9FVF APC Fixed Shelf - 50lbs/23kg, Black In Stock £81.12
9FVF APC Power Cord, C19 to CEE/7 Schuko, 2.5m In Stock £55.05
9FVF APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,501.84
9FVF APC NetShelter Zero U Accessory Mounting Bracket In Stock £66.51
9FVF APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £58.76
9FVF APC Smart-UPS X 120V External Battery Pack Rack/Tower In Stock £675.38
9FVF APC 1U Blanking Panel Kit In Stock £35.42
9FVF APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £56.50
9FVF APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.92
9FVF APC Power Cable (pack of 6) 1.22m In Stock £88.33
9FVF APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,703.48
9FVF APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £70.29
9FVF APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £100.94
9FVF APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £631.16
9FVF APC Replacement Battery Cartridge #143 In Stock £430.70
9FVF APC Metered Rack PDU In Stock £839.12
9FVF APC Switched Rack PDU AC 208-230 V Ethernet In Stock £743.29
9FVF APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,085.33
9FVF APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £61.55
9FVF APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £668.24
9FVF APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,246.30
9FVF APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £160.24
9FVF APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,295.76
9FVF APC Rack PDU Basic 0U/1U 100-240V/ In Stock £82.84
9FVF APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £466.02
Type: UPS
Brand: APC
Price Range Ex VAT: £1500+
