APC Smart-UPS X 1500VA Rack/Tower LCD 230V
Quicklinx: 74C5WS00 Mfr#: SMX1500RMI2U
Type: UPS
Power Rating: 1200Watt
£1,210.70 ex VAT
£1,452.84 inc VAT
Patent-pending operating mode that by passes unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Reduces or eliminates bulky transformers resulting in lighter units for ease of handling.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics
  • Cold-start capable
    Provides temporary battery power when the utility power is out
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection
  • High online efficiency
    Reduces utility costs, generates less heat
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning
  • SmartSlot
    Customize UPS capabilities with management cards
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users
  • Scalable runtime
    Allows additional run time to be quickly added as needed
  • Plug-and-Play external batteries
    Ensures clean, uninterrupted power to the loads when adding extra runtime to the UPS
  • Auto recognition of external batteries
    UPS recognizes when external battery packs are attached and automatically adjusts runtime
  • Rack/Tower convertible
    Protects the initial investment in the UPS when migrating from tower to rack-mount environment
  • Multiple switched outlet groups
    Multiple outlet groups that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding
  • High frequency design
  • EPO
    Attach the device to an Emergency Power Off (EPO) system so that power can be turned off in an emergency situation
APC Smart-UPS X 1500 Rack/Tower LCD - UPS - 1200 Watt - 1500 VA
UPS - rack-mountable
Rack Size
2U
24.8 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
1200 Watt / 1500 VA
Input Connectors
Power IEC 60320 C14
Output connectors
8 x power IEC 60320 C13
Lead Acid
Battery Form Factor
Plug-in module
Batteries Qty
1
Run Time (Up To)
5.8 min at full load
RS-232, USB
8.9 cm x 49 cm x 43.2 cm
3-year warranty
P/N: AR2487G, AR3100W, AR3105SP, AR3105W, AR3140G, AR3140W, AR3150W, AR3155SP, AR3155W, AR3300W, AR3305W, AR3340G, AR3355SP, AR3355W, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A
Battery Enclosure Type
Plug-in module
Height (Rack Units)
2U
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 285 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Provided
47 - 63 Hz
Frequency Required
50/60 Hz
Input Connectors
Power IEC 60320 C14
Output Voltage
AC 230 V 47 - 63 Hz
Power Capacity
1200 Watt / 1500 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
645 Joules
Quantity
1
Lead Acid
Run Time (Up To)
5.8 min at full load , 17.2 min at half load
Recharge Time
3 hours
Remote Management Interface
RS-232, USB
1 x management (RS-232) , 1 x management (USB) , 1 x EPO (emergency power off)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Serial cable - external , USB cable - external , Power cable - integrated - 1.8 m
Rack Mounting Kit
Included
Audible alarm, emergency power off, LCD display
C-Tick, UL 1449, VDE, EN 50091-2, RoHS Exemption 7b, EN 50091-1
Software Included
APC PowerChute Business Edition
Limited warranty - 3 years , Limited warranty - batteries - 2 years
45 °C
0 - 95%
Sound Emission
40 dBA
8.9 cm
49 cm
43.2 cm
24.8 kg
Shipping Width
24.6 cm
Shipping Depth
62 cm
Shipping Height
58.9 cm
Shipping Weight
30 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, ACF600, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR100, AR100HD, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
74C5 APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £30.95
74C5 APC Basic Rack-Mount PDU - power distribution strip In Stock £204.36
74C5 APC 1U Horizontal Cable Organiser In Stock £56.61
74C5 APC Netshelter heavy duty shelf In Stock £144.25
74C5 APC Rack PDU, Basic, Zero U, 10A,2 In Stock £280.19
74C5 APC Rack PDU Basic Zero U 16A 208/230V In Stock £303.36
74C5 APC 2-Post Mounting Kit for Smart-UPS In Stock £178.79
74C5 APC Rack PDU Basic Zero U 32A 230V In Stock £329.44
74C5 APC Temperature and Humidity Sensor In Stock £133.03
74C5 APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £300.02
74C5 APC Smart-UPS X-Series 48V Ext. Batt Pack Rack/Tower In Stock £670.52
74C5 APC Cable Managers (Qty 10) In Stock £37.12
74C5 APC Replacement Battery Cartridge In Stock £290.13
74C5 APC 2G Power distribution strip In Stock £648.80
74C5 APC Rack PDU 2G METERED ZEROU In Stock £706.28
74C5 APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £1,021.49
74C5 APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £979.84
74C5 APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,507.44
74C5 APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £59.45
74C5 APC 1U Blanking Panel Kit In Stock £35.50
74C5 APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £56.75
74C5 APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £49.71
74C5 APC Power Cable (pack of 6) 1.22m In Stock £90.64
74C5 APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,754.51
74C5 APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £70.53
74C5 APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £133.14
74C5 APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £105.31
74C5 APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £643.09
74C5 APC Extended Warranty Service Pack 3 Year In Stock £163.86
74C5 APC Metered Rack PDU In Stock £880.85
74C5 APC Switched Rack PDU AC 208-230 V Ethernet In Stock £762.02
74C5 APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,118.18
74C5 APC Service Pack 1 Year Warranty Extension In Stock £81.21
74C5 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £62.64
74C5 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £686.60
74C5 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,286.82
74C5 APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £164.54
74C5 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,333.77
74C5 APC Rack PDU Basic 0U/1U 100-240V/ In Stock £85.11
74C5 APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £466.49
Type: UPS
Brand: APC
Price Range Ex VAT: £1000 - £1500
