Product
APC Data Cable Partition 750mm
Quicklinx: 79DZWS00 Mfr#: AR8172BLK
Depth (mm): 7.2cm
Type: [N/A]
Width (mm): 73.2cm
£72.13 ex VAT
£86.55 inc VAT
Solid Shielding Partition facilitates overhead cable management, and offers protective grounding provisions and tool-less mounting.
  • Facilitates overhead cable management
    Overhead cable troughs and partitions install toollessly on the roof of the enclosure eliminating the need for ceiling mounted or underfloor mounted cable trays. Cable troughs and partitions are designed to manage both power and data cables while maintaining separation
  • Protective grounding provisions
    Safety protection against electric shock and reduction of EMI emissions. NetShelter Enclosures incorporate a series of ground studs within each enclosure, providing adequate means for grounding all loose sheet metal panels and/or internally rack-mounted equipment
APC cable shielding partition
Cable shielding partition
73.2 cm x 7.2 cm x 12.2 cm
2.3 kg
NetShelter; NetShelter SX
73.2 cm
7.2 cm
12.2 cm
2.3 kg
APC NetShelter , APC NetShelter SX
Depth (mm): 7.2cm
Type: [N/A]
Width (mm): 73.2cm
Brand: APC
Price Range Ex VAT: 50 - 100
