APC NetShelter SX 48U 600mm Wide x 1200mm Deep
Quicklinx: 53T9WS00 Mfr#: AR3307
Depth (mm): 120cm
Type: Floor standing
U Height: 48U
Width (mm): 60cm
£2,140.35 ex VAT
£2,568.42 inc VAT
The APC NetShelter SX is the next generation rack enclosure solution influenced by 10 years of customer feedback and addresses current IT market trends for high-density server and networking applications. With a strong focus on cooling, power distribution, cable management and environmental monitoring, the NetShelter SX provides a reliable rack-mounting environment for mission-critical equipment.
  • Robust design
    The APC NetShelter SX Enclosure with Roof and Sides is crafted to provide a sturdy and reliable housing solution for your computing equipment. Its robust design ensures your PC components are well-protected against physical impacts and environmental factors, offering peace of mind for the security and longevity of your technology investments.
  • Seamless compatibility
    Designed with PC compatibility in mind, this rack seamlessly integrates with your existing computing setup. It eliminates the hassle of mismatched components, ensuring a smooth and efficient organization of your PC hardware within a secure enclosure.
APC NetShelter SX Enclosure with Roof and Sides - rack - 48U
Rack
Rack Size
19"
Height (Rack Units)
48U
60 cm x 120 cm x 226 cm
150 kg
Wheels
5-year warranty
Rack
Rack Size
19"
Height (Rack Units)
48U
60 cm
120 cm
226 cm
150 kg
Weight Limit
1364 kg
Wheels
EIA-310-D, IEC 60529 IP20, BAA
TAA Compliant
Limited warranty: - 5 years
53T9 APC Basic Rack-Mount PDU - power distribution strip In Stock £205.78
53T9 APC 1U Vertical Cable Organiser In Stock £125.77
53T9 APC 1U Horizontal Cable Organiser In Stock £55.58
53T9 APC Smart-UPS SC 450VA 1U In Stock £276.02
53T9 APC Netshelter heavy duty shelf In Stock £145.67
53T9 APC Rack PDU, Basic, Zero U, 10A,2 In Stock £279.09
53T9 APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT In Stock £209.55
53T9 APC Rack PDU Basic Zero U 16A 208/230V In Stock £304.83
53T9 APC Smart-UPS 5000VA In Stock £3,681.10
53T9 APC Rack PDU Basic Zero U 32A 230V In Stock £328.60
53T9 APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £293.94
53T9 APC Smart-UPS X 1500VA Rack/Tower LCD 230V In Stock £1,197.35
53T9 APC Cable Managers (Qty 10) In Stock £36.45
53T9 APC 2G Power distribution strip In Stock £655.45
53T9 APC Rack PDU 2G METERED ZEROU In Stock £702.13
53T9 APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V In Stock £2,329.44
53T9 APC 1U 19" Black Modular Toolless Blanking Panel - Qty 200 In Stock £515.77
53T9 APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V w/ Network Card In Stock £2,691.25
53T9 APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £1,018.97
53T9 APC 19" Rack LCD Console In Stock £1,385.79
53T9 APC Fixed Shelf - 50lbs/23kg, Black In Stock £81.60
53T9 APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,518.27
53T9 APC NetShelter Zero U Accessory Mounting Bracket In Stock £99.79
53T9 APC Smart-UPS X 2200VA Rack/Tower LCD 200-240V - 4U In Stock £1,469.37
53T9 APC Smart-UPS X 3000 Rack/Tower LCD 2700 Watt 3000 VA In Stock £1,915.03
53T9 APC 1U Blanking Panel Kit In Stock £34.87
53T9 APC Smart-UPS SRT UPS 5000 Watt Lead Acid In Stock £4,096.74
53T9 APC Smart-UPS 1500VA LCD RM 1U 230V In Stock £975.30
53T9 APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £56.33
53T9 APC Smart-UPS SRT 6000VA RM 230V In Stock £4,800.92
53T9 APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.30
53T9 APC Smart-UPS SRT 8000VA RM 230V In Stock £6,198.22
53T9 APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £69.65
53T9 APC SMX3000HVNC Smart-UPS X1500VA Rack/Tower LCD230V In Stock £2,403.58
53T9 APC SMX1500RMI2UNC Smart-UPS 1500VA Rack/Tower LCD 230V with Net In Stock £1,654.88
53T9 APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £639.73
53T9 APC Smart-UPS SRT 2200VA RM 230V In Stock £1,814.79
53T9 APC Smart-UPS SRT 3000VA RM 2700 Watt 3000 VA - Lead Acid In Stock £2,831.48
53T9 APC Metered Rack PDU In Stock £863.02
53T9 APC Smart-UPS 1500VA RM 230V w/Network Card In Stock £1,191.39
53T9 APC Switched Rack PDU AC 208-230 V Ethernet In Stock £766.18
53T9 APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,128.72
53T9 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £62.92
53T9 APC Smart-UPS SRT 10000VA RM 230V In Stock £7,507.55
53T9 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £689.02
53T9 APC Smart-UPS C 1000VA 2U LCD - UPS (rack-mountable) In Stock £604.63
53T9 APC Smart-UPS 1000VA LCD RM - UPS (rack-mountable) In Stock £720.67
53T9 APC Smart-UPS 1500VA LCD RM - UPS (rack-mountable) In Stock £903.39
53T9 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,271.81
53T9 APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £164.37
53T9 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,309.18
53T9 APC Rack PDU Basic 0U/1U 100-240V/ In Stock £83.54
53T9 APC Smart UPS 2200VA LCD RM 2U 230 In Stock £1,545.19
53T9 APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £467.09
53T9 APC Smart-UPS SRT 3000VA RM Network Card In Stock £3,128.26
53T9 APC Smart-UPS SMT3000RMI2UC - UPS (rack-mountable) - AC 220/ In Stock £1,946.07
53T9 APC Smart-UPS 3000VA LCD RM - UPS (Rack-Mountable) AC 230 V In Stock £2,272.53
53T9 APC Smart-UPS 750VA RM 230V SmartConnect In Stock £528.94
Resources
The following resources are available for the APC NetShelter SX 48U 600mm Wide x 1200mm Deep
Depth (mm): 120cm
U Height: 48U
Width (mm): 60cm
Brand: APC
Price Range Ex VAT: £1500+
