Antec's HCG M power supplies are the perfect combination of power and efficiency. The HCG M features special heavy-duty High Current connectors and cabling that supply extreme levels of power, and superb efficiency thanks to 80 PLUS BRONZE certification and Active PFC. HCG M's innovative 16-pin sockets create a new level of flexibility by doubling the modular connectivity, supporting two different 8-pins connectors and even future connectors of 10, 12, 14 or 16-pins. Highest-quality connectors, Japanese-brand capacitors, and a quiet 135 mm double ball bearing LED fan complete the package. CircuitShield makes the HCG-750M safe and reliable in any environment with its nine industrial-grade protections.
Efficient cooling
Equipped with a 135 mm fan and dual ball bearing cooling system, this power supply ensures optimal thermal management, keeping your system cool even under heavy loads. -
Robust power delivery
With a 750 W output and dual 12V rails, the Antec High Current Gamer HCG-750M power supply delivers stable and reliable power to your PC components, supporting high-performance setups. -
Comprehensive protection
Featuring overcurrent, overheat, overpower, overvoltage, short-circuit, surge & inrush, and undervoltage protection, this power supply safeguards your system from a wide range of electrical risks. -
High compatibility
The power supply is compatible with a wide range of PC/Server configurations, thanks to its ATX12V 2.32/ EPS12V 2.92 compliance and a variety of power output connectors, including 24-pin ATX, 8-pin EPS12V, PCI Express, and Serial ATA power connectors. -
Energy efficient
Boasting an 80 PLUS Bronze certification and active Power Factor Correction (PFC), the HCG-750M operates at an efficiency of up to 88%, reducing electricity use and costs.
- Antec High Current Gamer HCG-750M - power supply - 750 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.32/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS Bronze
- 2.1 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Power Capacity
- 750 Watt
- Output Current
- +5V - 25 A , +12V1 - 40 A , +12V2 - 40 A , -12V - 0.5 A , +5VSB - 3 A , +3.3V - 25 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 8 pin PCI Express power with detachable 2 pin section , 9 x 15 pin Serial ATA power , 6 x 4 PIN internal power , 1 x 4 PIN mini-power connector
- Cooling System
- 135 mm fan
- 15 cm x 17 cm x 8.6 cm
- 5-year warranty
- PSU Form Factor
- ATX
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Input Voltage Margin
- + 10% / - 10%
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Power Capacity
- 750 Watt
- Output Current
- Efficiency
- 88%
- 80 PLUS Bronze
- Cooling System
- 135 mm fan
- Thermal monitoring, overheat protection, over current protection, over voltage protection, overpower protection, SLI ready, CrossFire ready, undervoltage protection, dual 12V rails, short-circuit protection, dual ball bearing cooling fan, surge & inrush protection
- UL, TUV, C-Tick, BSMI, cUL, CB, CCC, FCC, GOST-R, Energy-Related Products (ErP) Lot 6
- Limited warranty - parts and labour - 5 years
- 15 cm
- 17 cm
- 8.6 cm
- 2.1 kg
