Antec 750W High Current Pro 80plus Gold PSU
Quicklinx: 7N3GWS00 Mfr#: 0-761345-06239-8
HCP-750 unifies raw power with advanced PSU engineering to meet the demands of high performing PCs. A full-featured, 80 PLUS Gold certified unit, HCP-750 is capable of outputting 100 percent of its rated power on its four +12V rails to ensure CPU and graphics card compatibility. Exclusive to the High Current series, HCP-750 boasts High Current heavy-gauge 16 AWG wiring that boosts conductivity, increasing efficiency and improving power delivery. In addition, a double-layer PCB and onboard DC-to-DC converters provide substantial voltage stability. To tackle the needs of your system, pick up HCP-750.
Antec High Current Pro HCP-750 - power supply - 750 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3/ EPS12V 2.92
80 PLUS Certification
80 PLUS Gold
2.5 kg
United Kingdom
Input Voltage
AC 100-240 V
Power Capacity
750 Watt
Output Current
+5V - 25 A , +12V - 40 A , -12V - 0.5 A , +5VSB - 3 A , +3.3V - 25 A
Output connectors
4 x 8 pin PCI Express power with detachable 2 pin section , 9 x 15 pin Serial ATA power , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 1 x power 24 pin ATX with detachable 4 pin section , 6 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Cooling System
140 mm fan
15 cm x 18 cm x 8.6 cm
5-year warranty
PSU Form Factor
ATX
United Kingdom
Input Voltage
AC 100-240 V
Input Voltage Margin
+ 10% / - 10%
Frequency Required
50 - 60 Hz
Power Capacity
750 Watt
Output Current
80 PLUS Gold
MTBF
100,000 hours
Cooling System
140 mm fan
Overheat protection, gold-plated terminals, over current protection, over voltage protection, overpower protection, SLI ready, cable management, short-circuit protection, 4 x 12V rail, dual ball bearing cooling fan, CrossFireX ready
TUV, C-Tick, BSMI, cUL, CB, CCC, FCC, RoHS, GOST-R
Limited warranty - parts and labour - 5 years
15 cm
18 cm
8.6 cm
2.5 kg
