Anker Soundcore Liberty Air 2 - Black
Quicklinx: FXK2WS00 Mfr#: A3910G11
Two built-in microphones with uplink noise cancellation boost clarity by recognizing your voice and filtering out ambient noises to ensure you sound crystal-clear even in noisy spaces. Stereo calls further enhance call quality by allowing you to hear the other person's voice in both earbuds.
Graphene-coated drivers oscillate precisely, enabling Liberty Air to reproduce highly-accurate sound. Every detail of the music, from the deepest bass, to the brightest mids, and lush treble is delivered with extraordinary clarity and no distortion.
The latest Bluetooth 5.0 technology and a FPC antenna create a rock-solid connection for skip-free music. One-Step Pairing ensures that after the initial setup is complete, Liberty Air will automatically connect to your device the moment it's removed from the charging case.
A seamlessly concealed sensor in both the earbuds allows you to effortlessly answer calls or adjust music without reaching for your phone.
  • Sound with exceptional accuracy and clarity
    The diamond-inspired drivers are lightweight, yet rigid for precise sound reproduction and extended treble and bass.
  • aptX audio
    Ensures lossless sound transfer when streaming media from your device.
  • HearID tailored sound
    Maps your hearing sensitivity across multiple frequencies to create custom EQ settings for a truly personalized listening experience.
  • 22 EQ modes
    Use the Soundcore App to choose from a vast range of customized settings to get the most out of your favorite genres.
  • Crystal-clear calls
    4 microphones with the latest cVc noise reduction technology effectively highlight your voice while reducing background sounds.
  • Up to 28 hours of playtime
    Enjoy 7 hours of playtime on a single charge and extend to 28 hours with the charging case.
  • Fast-charging
    When you're running short on time, a 10-minute charge will give you 2 hours of listening.
  • Wireless charging compatible
    Simply place the charging case on a wireless charging pad for convenient charging.
  • Water-resistant design
    Liberty Air 2's IPX5-rated protection defends your earbuds against rain, sweat, and more.
  • Customizable EarTips
    Choose from 5 sizes of EarTips to find your perfect fit for enhanced passive noise cancellation and comfort.
Soundcore Liberty Air 2 - true wireless earphones with mic
True wireless earphones - Bluetooth
Headphones Form Factor
In-ear
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Impedance
16 Ohm
Max Input Power
5 mW
Microphone Noise Cancelling
Microphones Included
4
Controls
Volume, power on/off, answer/end, play/pause, next/previous track, reject call, voice assistant
18 months warranty
True wireless earphones - Bluetooth - wireless
HearID Technology, Diamond-Coated Driver
Protection
IPX5, water-resistant
Max Operating Distance
10 m
Audio Output
In-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Audio Codec
SBC, AAC, aptX
Bluetooth Version
Bluetooth 5.0
Bluetooth Profiles
Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Max Input Power
5 mW
Total Harmonic Distortion (THD)
1%
Impedance
16 Ohm
Diaphragm
6 mm
Microphone
Built-in
4
Noise Cancelling
Remote Control
Controls
Charging case (500 mAh), 5 pairs of ear tips (XS, small, medium, large, XL), USB-C charging cable
Headphone battery rechargeable
Included Qty
2
55 mAh
Run Time (Up To)
7 hour(s)
Run Time Details
Continuous playback: up to 7 hours , Continuous playback (with included charging case): up to 28 hours
Recharge Time
2 hour(s)
Limited warranty - 18 months
