Anker eufy RoboVac 15C
Quicklinx: FVXCWS00 Mfr#: T2120211
Select:
  • 15C
The Super Slim and WiFi Connected RoboVac
Eliminate Vacuuming Chores
RoboVac takes on dust busting around your home so you don’t have to. Multiple cleaning modes and auto clean scheduling ensure an effortless, thorough clean while you relax. And Amazon Alexa compatibility* means you can enjoy clean floors by just saying "Alexa, ask RoboVac to start cleaning."
Improved Cleaning
Refined from the inside and out to provide quiet vacuuming with zero hassle, RoboVac cleans with the equivalent sound of an operating microwave, and is only 2.85" tall to clean under low hanging furniture with ease.
Lean, Mean, Cleaning Machine
RoboVac may be super slim, but it’s packed with a 3 point cleaning system, BoostIQ technology, and up to 1300Pa of suction power to ensure your floors and carpets are clear of all dirt, dust, and crumbs.
Cleans Further
A larger 0.6L dustbin allows RoboVac to pick up more dirt and dust to take full advantage of 100 minutes** of continuous cleaning and without the need for emptying in between.
Premium Components
The anti scratch tempered glass cover provides a sleek look and superior protection for RoboVac, while the triple layer high performance filter achieves a better clean for your home.
For Optimal Use:
  • Use on low to medium pile carpets, tile, laminated, and hardwood floors.
  • Not suitable for high pile carpet.
  • Move cables out of the way to avoid entanglement. 5 cable ties are provided in the package to help you better organize wires and power cords.
Note: *Compared to previous eufy RoboVac models.
* Standard suction mode (hardwood floors) provides approx. 100 minutes of cleaning. BoostIQ mode (carpeting) provides approximately 60 minutes of cleaning. ** Alexa devices sold separately.
  • Just follow the sound
    If RoboVac gets stuck or is playing hide-and-seek, just tap the Find My Robot button in the EufyHome app to find it without effort.
  • Non-stop cleaning
    Large wheels roll over carpets and climb over door ledges to get to the mess.
  • Worry-free cleaning
    RoboVac uses drop-sensing technology to avoid falling down stairs and off of ledges.
  • Always prepared to clean
    RoboVac automatically returns to the charging base when power is low, ensuring it's always charged and ready to vacuum.
  • Triple-filter system
    RoboVac combines a dual-layer filter and one high-performance filter to achieve a clean home.
  • Automatic cleaning
    Multiple cleaning modes and a pre-set vacuuming time ensure an effortless, thorough clean while you do other things or nothing at all.
  • Endurance cleaning
    RoboVac cleans up to 100 mins per charge, so you get to enjoy a completely clean home from a single charge.
  • Large dustbox
    A large 0.6L dustbox holds more dirt per clean to reduce the frequency of emptying.
Eufy RoboVac 15C - vacuum cleaner - robotic - black
Vacuum cleaner
Cleaner Type
Robotic
Compatible Floor Type
General purpose
Cleaning Method
Dry
Control Type
Electronic
Control Elements
Push button
Communications Technology
Wi-Fi
Intelligent Assistant
Google Assistant, Alexa
Dust Collection
Bagless
Operating Autonomy
100 min
Sound Pressure Level (SPL)
55 dB
7.2 cm
1 year
Vacuum cleaner
Cleaner Type
Robotic
Vacuum Cleaner Type
General purpose
Carpet, hard floor
Cleaning Method
Dry
Dust Collection
Bagless
Filter Type
High Performance filter
Dust Capacity
0.6 litre
Suction Pressure
1.3 kPa
Room Navigation
Special Features
Edge cleaning, sensor technology
Settings, Controls & Indicators
Control Type
Electronic
Control Elements
Push button
Scheduling Presets
Smartphone Compatible
Internet of Things (IoT)
Wi-Fi
55 dB
Included Tools
Motorized brush, side brush (2x)
Remote control , Cleaning tool
Power Type
Rechargeable batteries
Operating Autonomy
100 min
Lithium Ion
Battery Voltage
14.4 V
Battery Capacity
2600 mAh
Full Charge Time
6 hrs
7.2 cm
Warranty
1 year
