Everything you love about Alexa, now in true wireless earbuds. Enjoy premium sound, limit background noise with Bose Active Noise Reduction. Advanced microphones give you hands-free access to Alexa - no tapping required.
Voice control your entertainment
Alexa is always ready to help you play music, identify an artist, or listen to a podcast or Audible audiobook. Just ask to skip songs, switch artists, or turn it up while your hands keep air drumming. -
Take Alexa with you
Now you can leave your phone in your pocket. Just ask Alexa to set a reminder, check your calendar, make a call, or get directions. Or press and hold your earbud to access Siri or Google Assistant from a supported device. -
Power up for work or play
Long-lasting battery and the charging case let you go with the flow, no matter what your day holds. -
Designed to protect your privacy
Alexa and Echo devices are built with multiple layers of privacy protection. For example, with Echo Buds, you can mute the mics with the Alexa app. You also have control over your voice recordings. You can view, hear, or delete them at any time.
- Amazon Echo Buds - true wireless earphones with mic
- Product Type
- True wireless earphones - Bluetooth
- Recommended Use
- Portable electronics
- Headphones Form Factor
- In-ear
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Sound Output Mode
- Stereo
- Active Noise Canceling
- Noise Isolating
- Microphone Operation Mode
- Beamforming
- Controls
- Mute, voice assistant
- Intelligent Assistant
- Siri, Google Assistant, Alexa
- 1-year warranty
- Product Type
- True wireless earphones - Bluetooth - wireless
- Dimensions & Weight Details
- Charging case: 7.7 cm x 5.7 cm x 2.9 cm / 70 g , Earbud: 2.2 cm x 2.3 cm x 2.4 cm / 7.6 g
- Recommended Use
- Protection
- Sweat-resistant, water-resistant
Audio Output
- In-ear
- Connectivity Technology
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Bluetooth Profiles
- Hands-Free Profile (HFP), Serial Port Profile (SPP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- Noise Isolating
- Active Noise Cancelling Technology
- Bose Active Noise Reduction
Microphone
- Form Factor
- Built-in
- Beamforming
Remote Control
- Controls
Tracking
- Sensors
- Accelerometer, proximity sensor, touch sensor
- Connector Type
- USB (5 pin Micro-USB Type B)
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Included Accessories
- 3 pairs of ear tips (small, medium, large), 3 pairs of wing tips (small, medium, large)
- Cable Details
- Micro-USB charge cable
- IPX4
- Battery
- Headphone battery rechargeable
- Run Time (Up To)
- 5 hour(s)
- Run Time Details
- Continuous playback: up to 5 hours , Continuous playback (with included charging case): up to 20 hours , Continuous talk (with included charging case): up to 16 hours , Continuous talk: up to 4 hours
- Limited warranty - 1 year
