Akasa P2 Series 3.5" USB External IDE Enclosure Silver
Quicklinx: 7FNJWS00 Mfr#: AK-ENP2USB-SLUK
Integral P2 designed for 3.5" IDE HDD with interface for all PATA drives up to 400Gb. A sleek aluminum external enclosure, which enables efficient heat dissipation. Stylish blue LED power and access indicator. Easily stackable- the Integral P2 series provides smart use of space.
Product Features
  • High speed USB 2.0 interface
  • Supports 3.5" IDE hard drives
  • Sleek aluminium case for efficient heat dissipation
  • Easy stack design for smart use of space
  • OS Support Win 2000/XP/Vista/7, Mac OS 9 and OS X
Technical Details
  • Application: External 3.5" IDE HDD enclosure
  • Interface: High Speed USB2.0 (1.1 compliant)
  • Data Transfer Rate: 480 Mb/s (max)
  • Material: Aluminium
  • Power & Access Indicator: Blue LED
  • DC input: 5V , 12V DC (power adapter)
  • Supported OS: Windows 2000/XP/Vista/7 Mac Os 9 and OS X
  • Plug & Play/Hot Swappable: Yes
  • Dimensions: 218 x 123 x 33 mm
Akasa Integral P2 AK-ENP2USB-SL - storage enclosure - ATA - USB 2.0
Storage enclosure - external
Bus Type
USB 2.0
Silver
Expansion Bays
1 x internal - 3.5"
Hard Drive Form Factor Compatibility
3.5"
ATA
Supported Devices
Hard drive
Product Material
Aluminium
Power Source
Additional USB
Apple MacOS 8.6 or later, Microsoft Windows 98SE/2000/ME/XP
12.3 cm x 21.8 cm x 3.3 cm
3.5"
Host Bus
USB 2.0
Product Material
Aluminium
Silver
Storage Controller
ATA
Supported Devices
Hard drive
Bays
1 x internal - 3.5"
1 x ATA
1 x USB 2.0 - 4 pin USB Type B
Carrying case
1 x USB cable - external
Plug and Play
Power Source
Additional USB
Power adapter
Software Included
Driver
12.3 cm
21.8 cm
3.3 cm
