ES is the entry level series of Akasa power supplies. These can be described as reliable, highly efficient and affordable. The ES power supplies have been designed with a no frills approach but still include many of the important features found on high-end power supplies.
Over 80% efficiency and built in active PFC provides energy saving clean power. The Ultra quiet thermally controlled 12cm fan ensures efficient cooling. Strong 12V output balanced on two rails delivers reliable system performance.
Fully sleeved cables complete with a generous number of connectors, including PCIe for graphics support. This provides great compatibility and makes it an ideal choice for mainstream and basic computing systems of today and the future.
- Energy saving active PFC
- Over 80% efficient
- Thermally controlled ultra quiet fan
- Dual 12V rail for stable power delivery
- PCIe connector
- Fully sleeved cables with black mesh
- Suitable for bottom case mounting
Spec
- Application 450W PC Power Supply
- Designed for AMD / INTEL based systems
- ATI-AMD / NVIDIA graphics
- Form factor ATX 12V 2.3
- Dimensions 150 x 140 x 86mm
- Typical efficiency Over 80%
- Power Factor Correction Active PFC
- Fan 120 x 120 x 25mm, thermal control
- Motherboard connector 1 (20+4pin )
- ATX12V connectors 1 (4pin)
- PCIe 6pin connectors 1
- SATA connectors 4
- Molex 4pin connectors 3
- FDD 4pin connectors 1
- Cable sleeve Black mesh (all cables, full length)
- AC power input 220~240V AC
- Protection Over Power / Voltage / Current Protection
- Safety CE, CB
- Product code AK-P450AG8-SLEU (Europe)
