3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit standard desktop LCD monitors with a diagonally measured 17 1/16" viewing screen and a 5:4 aspect ratio. Actual filter dimensions are 13 5/16" wide x 10 11/16" high (338 mm x 271 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
- 3M PF17.0 display privacy filter - 17"
- Product Type
- Display privacy filter
- Display Screen Size Compatibility
- 17"
- Package Type
- Retail
- 1 year warranty
- Product Type
- 17"
- Package Type
- Retail
- 1 year warranty
- Service & Support Details
- Limited warranty - 1 year
