3M 30.0" Widescreen (16:10) Monitor Privacy Filter - Frameless
Quicklinx: 9ZBYWS00 Mfr#: PF30.0W
Accessory Type: Privacy Screen
£103.24 ex VAT
£123.88 inc VAT
3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 29 3/4" viewing screen and a 16:10 aspect ratio. Actual filter dimensions are 25 3/16" wide x 15 3/4" high (641 mm x 401 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
3M PF30.0W - display privacy filter - 30" wide
Display privacy filter
Display Screen Size Compatibility
30" wide
64.1 cm 40.1 cm
1 year warranty
30" wide
64.1 cm 40.1 cm
Anti-reflective, easy-to-remove
1 year warranty
Service & Support Details
Limited warranty - 1 year
Brand: 3M
