Display and device technology continues to advance. So do we. Behind the simplicity of our products is a powerful combination of optical science and sheer ingenuity you’ve come to expect from 3M. The microlouver technology in our world-class privacy filter helps protect the confidential and sensitive information displayed on your monitor from the side-views of visual hackers. The matte surface helps reduce glare and hide fingerprints, so you get crisp image clarity on your screen, while visual hackers with side views are kept in the dark.
Enhanced privacy
Equipped with Micro-Louver technology, the 3M Privacy Filter for 19" Monitors 5:4 ensures that your information remains confidential, offering a 60° viewing angle that keeps your data visible only to you. -
Versatile viewing
This privacy filter offers both glossy and matte surface finishes, allowing you to choose the viewing experience that best suits your needs, whether you're aiming for reduced glare or a clear, vivid display. -
Durable design
With its scratch-resistant feature, the 3M Privacy Filter stands up to everyday wear and tear, ensuring that your screen not only stays private but also protected from potential damage. -
Easy installation
The package includes adhesive strips and slide mounts, making the installation process straightforward and hassle-free, allowing for landscape mounting that fits perfectly with your 19" monitor. -
Reversible functionality
Designed to be frameless and reversible, this privacy filter offers the flexibility to choose between a glossy or matte finish, adapting to changing lighting conditions or personal preferences for screen clarity and glare reduction.
- 3M Privacy Filter display privacy filter - 19"
- Product Type
- Display privacy filter
- Package Content
- Slide mounts, adhesive strips
- Black
- Display Screen Size Compatibility
- 19"
- 1-year warranty
- Product Type
- Package Content
- 19"
- Black
Display Filter
- Viewing Area Height
- 37.7 cm
- Viewing Area Width
- 30.2 cm
- Aspect Ratio
- 5:4
- Surface Finish
- Glossy/matte
- Scratch Resistant
- Anti-glare, reversible, Micro-Louver technology, frameless, 60° viewing, landscape mounting
- Limited warranty - 1 year
