Zyxel PoE12-HP Single Port High Power PoE Injector
Quicklinx: 8TZDWS00 Mfr#: POE12-HP-GB0102F
ZyXEL PoE-12 is a single-port Power over Ethernet (PoE) Injector that infuses and transmits electricity through unused pairs (4/5 and 7/8) in CAT-5 Ethernet cables, while data flows are carried by the other pairs (1/2 and 3/6). As such both power and data can be delivered to PoE devices (PD) via a single CAT-5 Ethernet cable without extra power supply.
With the PoE-12, non-PoE switches can now power IEEE802.3af compliant PoE devices through an effective single CAT-5 Ethernet cable link up to 100m in length.
In other words, users can install any IEEE 802.3af compliant PoE devices like WLAN access points or IP surveillance cameras with more freedom. Unlike traditional solutions, the PoE-12 can now take advantage of the effortless connectivity in challenging places, such as ceiling or top of wall, without laying power cables. It means that the devices are now untied from power outlets for maximum flexibility.
The PoE-12 is easy to use and needs no configuration. Since only simple inbound and outbound cable plugging is required, installation is straightforward and can be performed by users without power cabling expertise or expense.
Zyxel PoE 12HP - PoE injector - 30 Watt
PoE injector - external
396 g
United Kingdom
Input Voltage
AC 100-240 V
Power Capacity
30 Watt
Output connectors
1 x RJ-45
15.5 cm x 7.4 cm x 3.6 cm
United Kingdom
Input Voltage
AC 100-240 V
Frequency Required
50/60 Hz
42.1 Watt
1 x RJ-45
Max Electric Current
1.5 A
Power Capacity
30 Watt
1 x Gigabit LAN - RJ-45
CSA, FCC Part 15 B, EMC, RoHS, EN 60950-1
50 °C
10 - 95% (non-condensing)
15.5 cm
7.4 cm
3.6 cm
396 g
Shipping Width
20.2 cm
Shipping Depth
15.5 cm
Shipping Height
6.9 cm
Shipping Weight
0.78 kg
