Zyxel GS3700-48HPL2/3 48 port PoE+ Gigabit Switch
THE SWITCH EXPERT
Quicklinx: 8XFXWS00 Mfr#: GS3700-48HP-ZZ0101F
The ZyXEL XGS3700 series are advanced layer 2 plus Gigabit managed switches perfect for data center access, SMB core/aggregation, and mission critical PoE applications. The series consists of eight models including 48 port configurations, PoE and non-PoE models, as well as 10GbE uplink options. The complete series is designed with an advanced feature set with static routing, policy-based routing (PBR), VRRP and ECMP support. The high redundancy hardware architecture includes dual, internal power supplies and hot-swappable fan and power modules. The PoE models also comply with the IEEE 802.3at PoE Plus standard and provide industry-leading PoE power budget of up to 1000 watts.
  • Resiliency and availability for non-stop business continuity
    The ZyXEL XGS3700 series features a no single point of failure (NSPOF) hardware and software design to provide the resiliency needed for non-stop business continuity. Its high redundancy hardware architecture includes dual, internal power supplies - which not only ensures 100% uptime in the event of a power supply failure, but also saves rack space compared to external power supplies. Additionally, both the fan module and the power supply modules are hot-swappable to enable zero downtime troubleshooting. With ECMP, the XGS3700 series switch can distribute tragic across multiple high-bandwidth links to increase bandwidth availability. VRRP provides a dynamic and automatic approach to virtual router redundancy. It allows several first-hop virtual routers to dynamically share an IP address, with one assigned as master and the others as backup. Should the master fail, a backup is automatically assigned to ill its place. The result is improved network resiliency and lower administrative overhead compared to running dynamic routing protocols or client discovery mechanisms.
  • High power capacity and high availability for mission critical PoE applications
    The ZyXEL XGS3700 series features high power PoE models in 48 port configurations. The complete PoE portfolio provides up to 30 watts per port with IEEE 802.3at PoE plus compliance, and is backward compatible with the IEEE 802.3af standard. All models provide an industry- leading PoE power budget of 1000 watts with dual power supply units or 460 watts with a single power supply unit. Combined with the high resiliency hardware and software features, the XGS3700 series PoE switches are ideal for mission critical IP surveillance, WLAN and high quality VoIP applications.
  • Deployment flexibility and investment protection
    With a comprehensive portfolio of 48-port, PoE/non-PoE and 10GbE uplink configurations, the ZyXEL XGS3700 series provides the flexibility to be deployed in all sorts of deployments including data center access, SMB core/aggregation, and mission critical PoE applications. The Series provides added routing flexibility with support for static routing and policy-based routing (PBR); and its full and consistent GUI, CLI and MIB ensures simplified management and consistent configurations. Investment protection is guaranteed with the ZyXEL XGS3700 series. Its high port density and high power budget design leaves room for future deployment expansion and eliminates the need to purchase additional equipment. The four 10GbE ports on the XGS3700 models facilitate easy transition to 10GbE networking in data center and enterprise networks, while full IPv6 support ensures that your network is ready for the future.
Zyxel XGS3700-48HP - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L2+ - Managed - stackable
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE+) + 4 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
460 W
Performance
Switching capacity: 176 Gbps , Forwarding performance: 131 Mpps
Routing table entries: 512 , Routing domains: 128
MAC Address Table Size
16K entries
Routing Protocol
IGMPv2, IGMP, VRRP, static IP routing, IGMPv3, ECMP, policy-based routing (PBR)
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, SSH-2, CLI
Flow control, ARP support, trunking, IGMP snooping, Syslog support, traffic shaping, port mirroring, DiffServ support, WRR queuing, MAC address filtering, Broadcast Storm Control, IPv6 support, IP address filtering, Multicast Storm Control, Unicast Storm Control, firmware upgradable, WFQ, ZyXEL iStacking Technology, sFlow, STP support, RSTP support, VRRP support, VLAN Stacking, MSTP support, DHCP snooping, ACL support, RADIUS support, DHCP server, MLD snooping, bandwidth control, ECMP, LLDP support, DHCP relay, LACP, NTP server, IP-MAC binding, DHCP client, MIB, MVR, dual firmware images, SPQ, 2MB packet buffer, loop prevention, port isolation, hot swappable fan, CoS, tagged VLAN, GVRP, IGMP proxy
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.3ah, IEEE 802.1ag, IEEE 802.1ab (LLDP), IEEE 802.3aq, IEEE 802.3at, IEEE 802.3az
Power Redundancy
Optional
44 cm x 43.7 cm x 4 cm
8.02 kg
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
460 W
Performance
16K entries
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
48 x 1000Base-T RJ-45 PoE+ - 30 W , 4 x SFP+ , 1 x console - 9 pin D-Sub (DB-9) , 1 x RJ-45 management
Internal power supply
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
600 Watt
MTBF
200,000 hours
BSMI, RoHS, FCC Part 15 B Class A, LVD, EMC Class A
44 cm
43.7 cm
4 cm
8.02 kg
50 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
10 - 90% (non-condensing)
