Zyxel GS1920-8HPv2, 10 Port Smart Managed Switch
Quicklinx: HHYVWS00 Mfr#: GS1920-8HPV2-GB0101F
20 In Stock
£148.65 ex VAT
£178.38 inc VAT
The GS1920 series is ideal for SMB deployment in multiple scenarios, with its unique port combinations future proofing your network to ensure easy growth down the road.
  • Whisper-quiet operation
    Smart fan and fanless designs for silent operation in your workplace.
  • User-friendly LED indicators
    View real-time status instantly with cloud and PoE power-usage LED indicators.
Zyxel GS1920-8HPv2 - switch - 8 ports - smart
Switch - 8 ports - smart
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
130 W
Performance
Switching capacity: 20 Gbps , Forwarding rate: 15 Mpps
QoS hardware queues per port: 8
MAC Address Table Size
16K entries
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c
Flow control, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, MAC address filtering, Broadcast Storm Control, IPv6 support, IP address filtering, Multicast Storm Control, Unicast Storm Control, firmware upgradable, WFQ, ZyXEL iStacking Technology, STP support, RSTP support, MSTP support, DHCP snooping, QoS, RADIUS support, MLD snooping, fanless, DHCP relay, Port Security, SNMP trap, DHCP client, MIB, MVR, GVRP, dual firmware images, SPQ, NDP, port isolation, CoS, IGMP proxy, 802.1x authentication, Duplicated Address Detection, cloud managed, DSCP support, 1.5MB packet buffer, ErrDisable Recovery, IGMP filtering, IGMP throttling, Protocol-based VLANs support, CPU protection, IP source guard, ARP inspection, ICMP, VLAN filtering, Loop Guard, Voice VLAN, Private VLAN, Guest VLAN, WRR, MAC based VLAN, VLAN Tagging, port-based VLAN, Unknown Storm Control, MRSTP, MAC freeze
IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
26.7 cm x 16.2 cm x 4.4 cm
1.9 kg
United Kingdom
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
130 W
Performance
16K entries
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+
RAM
256 MB
Flash Memory
32 MB
8 x 1000Base-T RJ-45 PoE+ - 30 W , 2 x 1000Base-X SFP , 2 x 1000Base-T RJ-45
Internal power supply
161.8 Watt
Wall mounting kit, desk mount kit
MTBF
513,985 hours
BSMI, RoHS, FCC Part 15 A, LVD, EMC Class A
United Kingdom
26.7 cm
16.2 cm
4.4 cm
1.9 kg
Shipping Width
37.5 cm
Shipping Depth
23.5 cm
Shipping Height
6.1 cm
Shipping Weight
2.73 kg
Limited warranty - lifetime
50 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Brand: Zyxel
