Zyxel GS2210-48HP 48 port Gigabit L2 Managed PoE+ Switch
Quicklinx: BW42WS00 Mfr#: GS2210-48HP-GB0101F
The ZyXEL GS2210 series are fully featured Layer 2 Gigabit access switches designed to meet these converged data, video and voice networking challenges. The series comes in 48-port model with a combination of GbE RJ-45, GbE SFP and GbE combo (RJ-45/SFP) connectivity. The PoE model comply with the IEEE 802.3af PoE and 802.3at PoE Plus standards and provide a high PoE power budget of 375 watts. The GS2210 series supports ZON utility and ZyXEL one network inter-device features that make network setup and maintenance easier, more efficient, and more unified than ever before. With rich traffic shaping, network isolation, and security features, the GS2210 series is the perfect L2 access switch solution for converged data, video and voice networking.
  • Agile traffic control for converged networking applications
    Designed for access layer converged data, video and voice applications, the ZyXEL GS2210 series has a rich Layer 2 feature set that can shape the traffic for diverse VoIP, video conference, IPTV and IP surveillance deployments. Supporting L2 multicast and IGMP snooping, the GS2210 series can support large IPTV deployments, while using bandwidth efficiently by directing multicast traffic to the subscribers only. The Multicast VLAN Registration (MVR) function ensures better network security by allowing a single multicast VLAN to be shared in the network while subscribers remain in separate VLANs. In terms of voice, the GS2210 switch uses OUI to detect compliant IP phones, and then assigns the delay-sensitive VoIP traffic to a dedicated voice VLAN with appropriate QoS prioritization. These advanced traffic control features of the GS2210 series provide hotels, businesses and educational institutions greater agility and more effective traffic management for the converged applications of today.
  • Intelligent and high-powered Power over Ethernet (PoE)
    The ZyXEL GS2210 series PoE switches feature advanced and intelligent PoE functions that simplify and lower the cost of PoE deployments such as IP telephony, WLAN and IP surveillance. This series of L2 PoE switches support the IEEE 802.3af PoE and 802.3at PoE Plus standards, which provide up to 30 watts of power per port for advanced Powered Devices (PD) like 802.11ac wireless APs and video IP phones. The high power budget of 375 watts enables the GS2210 PoE switches to comfortably accommodate the PDs required in a modern network edge. The intelligent PoE technology used in the GS2210 PoE switches enables more efficient use of power resources that delivers better ROI for businesses. Setting the PoE switch to Consumption Mode, it can automatically detect the power consumption status of each Powered Device and supply only the amount of power required. This intelligent power allocation function minimizes the waste of unused power, helps businesses save money, and enables the PoE switch to power more PDs.
  • High level network and access security
    Equipped with an extensive array of access security, traffic security and network storm protection features, the ZyXEL GS2210 series offers enhanced control and isolation for improved convergence of video, voice and data. Such advanced defense mechanisms as IP source guard, DHCP snooping, and ARP inspection can detect and block intentional network attacks. The CPU protection function ensures normal switch operation by preventing malicious traffic from trying to shut down the switch. Combining multiple L2, L3 and L4 filtering mechanisms with such education- and hospitality-friendly features as MAC freeze, port isolation and guest VLAN, the ZyXEL GS2210 series offers a high level of security, flexibility and control for diverse access layer deployments.
  • Future-proof connectivity for evolving networks
    The ZyXEL GS2210 series helps businesses and organizations stay ahead and get ready for future IPv6 networks. It supports dual stack (IPv4 and IPv6) and IPv6 host that allows businesses and organizations to deploy the GS2210 switch at the network edge today, and easily migrate to the next-generation Internet Protocol in the future. With support for IPv6 ACL packet filtering, the GS2210 L2 Gigabit switch can create secured IPv6 networks that are protected from illegal IPv6 clients. The GS2210 series is designed with a comprehensive set of IPv6 management features that include ICMPv6, neighbor discovery and DHCPv6 relay, which facilitate the migration to next-generation networking applications without an extensive equipment upgrade.
  • Easier, more efficient setup and management
    Part of the ZyXEL one network experience, the GS2210 series supports ZON utility and innovative inter-device features to deliver the easiest, most efficient network setup and management for businesses. The ZyXEL one network inter-device features allow the switch to discover neighbor ZyXEL devices so users can see what devices are connected to the switch, what ports are used, device IP and even firmware version. From there, users can easily access neighbor device GUIs with one click. The PoE models can additionally reset neighbor devices to factory defaults or power cycle neighbor PDs remotely to speed up network troubleshooting.
Zyxel GS2210-48HP - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed - stackable
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
44 x 10/100/1000 (PoE+) + 2 x Gigabit SFP + 4 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
375 W
Performance
Switching capacity: 100 Gbps , Forwarding performance: 74 Mbps
MAC Address Table Size
16K entries
Routing Protocol
IGMPv2, IGMP, IGMPv3, policy-based routing (PBR)
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, SSH-2, CLI
Flow control, Layer 2 switching, ARP support, VLAN support, IGMP snooping, Syslog support, traffic shaping, port mirroring, WRR queuing, MAC address filtering, Broadcast Storm Control, IPv6 support, IP address filtering, Multicast Storm Control, Unicast Storm Control, firmware upgradable, WFQ, ZyXEL iStacking Technology, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, RADIUS support, MLD snooping, IPv4 support, LLDP support, DHCP relay, LACP, Port Security, NTP server, IP-MAC binding, DHCP client, Energy Efficient Ethernet, MVR, dual firmware images, SPQ, loop prevention, port isolation, CoS, tagged VLAN, GVRP, DSCP support, 1.5MB packet buffer, ErrDisable Recovery, ZDP, ZON, IGMP filtering, IGMP throttling
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
44 cm x 33 cm x 4.45 cm
5.13 kg
Europe
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
375 W
Performance
16K entries
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
Status Indicators
Power, system, link/activity
44 x 1000Base-T RJ-45 PoE+ - 30 W , 6 x SFP , 1 x serial (RS-232) DB-9 , 4 x 1000Base-T RJ-45
Internal power supply
461 Watt
MTBF
120,760.8 hours
BSMI, RoHS, FCC Part 15 A, LVD, EMC Class A, BSMI ENC
Europe
44 cm
33 cm
4.45 cm
5.13 kg
50 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
10 - 90% (non-condensing)
