Zyxel GS1510-24 24 port Gigabit Web Managed Switch
Quicklinx: 7BFTWS00 Mfr#: 91-010-236003B
The ZyXEL GS1510 series is a user-friendly solution aiming at office network environments demanding silent operation and green technology. The series provides security and Plug-and-Play simplicity for sustainable high-bandwidth connectivity.
The GS1510-24 Switch offers two open Gigabit SFP slots to provide more flexibility on fiber connectivity for long loop reach applications. The GS1510 series not only provides Layer-2 switching capability at wire speed over the current CAT-5 cabling to desktops following the IEEE standards, but also features high performance, ease of use, flexible deployment and enhanced energy efficiency. It is ideal for small businesses to protect the existing network investments while extending managed networks.
  • Secure your network
    To address security needs, The GS1510 series not only supports 802.1X port-based authentication that allows the network to be authenticated through external RADIUS servers, but also enables web authentication to provide enhanced, secured collaboration with ZyXEL's NWA3000 AP series switch.
  • Easy installation and management
    The GS1510 series offers plug-and-play connectivity and easy installation. With the auto MDI/MDI-X feature, it eliminates the need for crossover cables when connecting to another switch or hub; in addition, the auto-negotiation feature senses the link speed of a connected network device then intelligently makes adjustments for compatibility and optimal performance. The GS1510 series also offer easy management to fulfill user needs through SNMP and the web-based GUI that provides two modes: the smart mode and the advance mode.
  • Green networking
    The GS1510 series has environment-awareness along with Gigabit Ethernet speeds critical for the next-generation network applications and provides power saving functions to reduce energy consumption and to help businesses save cost.
  • Fanless design
    Since the fanless design ensures quiet operation in small office spaces, the GS1510 series is the perfect solution for small business and SOHO office deployments. The design promotes quieter environments and less heat dissipation, and it offers energy and cost saving properties without affecting the desirable performance, making it an ideal solution for growing businesses and operators.
Zyxel GS-1510-24 - switch - 24 ports - Managed
Switch - 24 ports - Managed
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 2 x SFP
MAC Address Table Size
16K entries
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 2c, HTTP
Flow control, Layer 2 switching, auto-negotiation, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, Weighted Fair Queuing (WFQ), Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Quality of Service (QoS), Jumbo Frames support
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3az
44 cm x 17 cm x 4.4 cm
2.4 kg
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
16K entries
Routing Protocol
Status Indicators
Port status, power, system, link/activity
24 x 1000Base-TX RJ-45 , 2 x SFP (mini-GBIC)
Internal power supply
20 Watt
RoHS, IEC 60950-1, EN 60950-1, FCC Part 15 A, CSA C22.2 No. 60950-1
44 cm
17 cm
4.4 cm
2.4 kg
50 °C
10 - 95% (non-condensing)
