Brand
Zyxel GS1100-10HP Unmanaged PoE 8xGigabit, 2xFiber Uplink 120 Watt
Quicklinx: C1J3WS00 Mfr#: GS1100-10HP-GB0101F
The ZyXEL GS1100 series is the optimal solution for instant Gigabit connectivity in office environments demanding silent operation and better energy efficiency. With power-saving functions, Gigabit Ethernet and a fanless design, the GS1100 series provides Plug and Play simplicity for high-bandwidth network applications. The GS1100 series not only offers Gigabit Ethernet connectivity for advanced network applications, but also power-saving functions for better energy efficiency. Capable of dynamically adjusting power output according to traffic, active links and cable length, the GS1100 series can reduce energy consumption.
  • Green networking
  • Fanless design
    The complete GS1100 series comes in a fanless design that ensures silent operation in small or quiet office environments. The GS1100-10HP PoE model was specifically designed with an external power adapter that eliminates the need for an additional fan to cool down the device, making it perfect for quiet PoE deployments.
  • Gigabit to the desktop
    The ZyXEL GS1100 series offers small offices optimal 8 / 10 / 16 / 24-port Gigabit connectivity. Additionally, the GS1100-10HP model is equipped with 2 extra SFP slots, supporting dual rate that enables fiber optic connections for long-distance deployments. With Gigabit network performance, the GS1100 series is the ideal solution for bandwidth-intensive applications such as high-resolution photo transmission, video / audio streaming and server farm connections.
  • Freedom of installation via PoE
    The GS1100-10HP supports the PoE Plus standard to ease the installation of network devices in challenging spaces such as ceilings or walls. The low power supply per port allows the GS1100-10HP to power PoE-enabled WLAN APs, VoIP phones and IP surveillance cameras through cables without extra power adapters. This feature helps enterprises reduce installation time and cost when there are many such devices on the network. The GS1100-10HP has been designed with eight full PoE Plus ports, which makes it an ideal connectivity solution for high-density powered device deployments. In addition, the extra two SFP links on GS1100-10HP also easily extend networks to remote locations such as branch offices and warehouses for small- and medium-size businesses.
Zyxel GS1100-10HP - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 2 x Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
130 W
Performance
Switching capacity: 20 Gbps , Forwarding performance: 14.88 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Flow control, VLAN support, auto-uplink (auto MDI/MDI-X), Broadcast Storm Control, fanless, Energy Efficient Ethernet, 256KB packet buffer, Class of Service (CoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
25 cm x 10.4 cm x 2.7 cm
730 g
United Kingdom
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
130 W
Performance
8K entries
Jumbo Frame Support
9KB
Status Indicators
Port status, power, PoE, link/activity
8 x 1000Base-T RJ-45 PoE+ , 2 x SFP
156.1 Watt
MTBF
1,000,070 hours
RoHS, IEC 60950-1, EN 60950-1, BSMI CNS 13438, LVD, BSMI CNS 14336-1
United Kingdom
25 cm
10.4 cm
2.7 cm
730 g
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
