Robust Design
ZyXEL's ES-1552 ExtraSmart Switch comes with 52 Fast Ethernet copper ports plus four Gigabit uplinks (two 1000Base-T ports and two SFP slots) that power the non-blocking connection power to SMB/SB networks, and the multi-function design fits into copper or fiber networks easily.
By utilising 4G uplinks and port aggregation, bandwidth on critical paths can be expanded flexibly by merging multiple traffic pipelines into one to dramatically improve network stability.
ExtraSmart™ Evolution
While many legacy web smart switches improve manageability they can often be complex to use. For most small businesses, inadequate IT expertise and complicated configurations are the major pains to overcome. Powered by a new hardware platform with smart ACL technology; "Auto DoS Attack Prevention" and "Auto VoIP" features provides hassle-free operation.
In addition, ZyXEL ES-1552 comes with a streamlined intuitive Web-GUI for features such as 802.1Q VLAN, 802.1p traffic priority and static port aggregation.
Extra Secure - Auto DoS Attack Prevention
Security is a top priority for SMB/SB networks. Equipped with Auto DoS Attack Prevention, the ES-1552 ExtraSmart Switch is capable of fighting against ubiquitous DoS attacks.
A few mouse clicks is all it takes to initiate the protection and complete the once-complicated ACL setting, reducing the time required with switch setup and management.
ES-1552 supports 802.1Q VLAN for traffic isolation, as well as static MAC forwarding and dynamic ARP to establish a robust protected network.
Auto VoIP Telephony without the Configuration headaches
VoIP is becoming more popular within businesses, but it usually requires IT expertise to optimise a network for VoIP applications. The "Auto VoIP" feature of the ES-1552 ExtraSmart Switch can identify VoIP packet patterns and approve the highest priority to VoIP-friendly communications.
Auto VoIP offers IP telephony without the configuration headaches. Features like four priority queues and a WFQ scheduling algorithm allows users to optimise network bandwidth usage and quality of services.
In terms of bandwidth management, users can choose from several options and pick the most appropriate.
Integrate into existing networks easily
ZyXEL's ES-1552 Web managed extra smart Ethernet switch includes 52 fast Ethernet copper ports plus four Gigabit uplinks (two 1000Base-T ports and two SFP slots) which provide non-blocking connection power to networks. The flexible multi function design means the switch can integrate easily into any network. By utilizing 4G uplinks and port aggregation functionality, the bandwidth on critical paths can provide resilience by merging multiple traffic pipelines into logical ones, dramatically increasing network stability. -
Simple management with web GUI
The inclusion of a streamlined intuitive web GUI simplifies the setup of features and configuration such as 802.1Q VLAN, 802.1p traffic priority and static port aggregation. Many legacy web smart switches improve manageability but can often be complex to use. Powered by a new hardware platform with smart ACL technology; "Auto Dos Attack Prevention" and "Auto VoIP" management features provides hassle-free operation. -
Robust security
Auto Dos Attack Prevention features mean the ES-1552 ExtraSmart Switch is highly capable of protecting against Dos attacks. A few clicks of the mouse are all that is required to initiate the protection features. Supporting 802.1Q VLAN for traffic isolation, as well as static MAC forwarding and dynamic ARP allows a strictly protected network to be created. -
One click setup - auto VoIP, QoS and bandwidth management
Auto VoIP reduces the time required to setup VoIP on a network. It works by identifying VoIP packet patterns and then grants the highest priority to establish a VoIP-friendly communication. "Auto VoIP" also offers IP telephony without the configuration headaches. Featuring four priority queues and a weighted fair queueing scheduling algorithm, the ES-1552 Switch allows administrators to optimize network bandwidth usage and maintain quality of service.
- Zyxel Dimension ES-1552 - switch - 48 ports - Managed
- Switch - 48 ports - Managed - stackable
- Subtype
- Fast Ethernet
- Ports
- 48 x 10/100 + 2 x SFP + 2 x 10/100/1000
- MAC Address Table Size
- 8K entries
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON, HTTP
- Flow control, Layer 2 switching, auto-negotiation, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), traffic shaping, DoS attack prevention, port mirroring, manageable, stackable, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, firmware upgradable, Weighted Fair Queuing (WFQ), Access Control List (ACL) support, Quality of Service (QoS), Data prioritization (Qos) for VoIP applications
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP)
- Power
- AC 120/230 V (50/60 Hz)
- 44.1 cm x 19.5 cm x 4.5 cm
- 2.7 kg
- Enclosure Type
- Desktop
- Subtype
- Fast Ethernet
- Ports
- 8K entries
- RAM
- 512 KB
- Status Indicators
- Port status, port transmission speed, power, link OK, link/activity
- 48 x 100Base-TX RJ-45 , 2 x 1000Base-T RJ-45 , 2 x SFP (mini-GBIC)
- Power Device
- Internal power supply
- Voltage Required
- 20.5 Watt
- CSA 22.2 No. 60950, FCC Part 15, UL 60950-1, IEC 60950-1, EN 60950-1
- 44.1 cm
- 19.5 cm
- 4.5 cm
- 2.7 kg
- 0 °C
- 45 °C
- 10 - 90%
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £7.93 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.55 |
