- Antenna gain level (max): 7 dBi
- Frequency band: 2.4/5 GHz
- Antenna type: Omni-directional
- Antenna connector type: N-type
- Antenna gain (2.4 GHz): 4.5 dBi
- Antenna gain (5 GHz): 7 dBi
Enhanced connectivity
The Zyxel ANT2105 boosts your signal strength with a gain of 4.5 dBi for 2.4 - 2.483 GHz and 7 dBi for 5.15 - 5.875 GHz frequencies, ensuring reliable, wide-reaching wireless coverage for various outdoor environments. -
Durable design
Built to withstand harsh conditions, this antenna operates flawlessly in a humidity range of 0 - 95% and temperatures ranging from -10°C to 70°C, making it an ideal choice for outdoor deployment. -
Versatile placement
With its omnidirectional directivity and a 360° horizontal beamwidth, the ANT2105 offers flexible mounting options, ensuring consistent signal quality and coverage in all directions. -
Optimized performance
Featuring a low Voltage Standing Wave Ratio (VSWR) of 2.0:1, this antenna is designed for efficient performance, minimizing signal loss and maximizing output for your connectivity needs.
- Zyxel ANT2105 - antenna
- Product Type
- Antenna
- Packaged Quantity
- 2 (specifications are for single item)
- 2.2 cm x 2.2 cm x 18.3 cm
- 70 g
- Grey
- Aerial Placing / Mounting
- Outdoor
- Frequency Range
- 2.4 - 2.483 GHz, 5.150 - 5.875 GHz
- Gain
- 4.5 dBi (for 2.4 - 2.483 GHz), 7 dBi (for 5.15 - 5.875 GHz)
- Directivity
- Omni-directional
- 2-year warranty
- Packaged Quantity
- Product Type
- Antenna
- 2.2 cm
- 2.2 cm
- 18.3 cm
- 70 g
- Enclosure Colour
- Grey
Aerial
- Outdoor
- Frequency Range
- Gain
- Directivity
- Omni-directional
- Voltage Standing Wave Ratio (VSWR)
- 2.0:1
- Horizontal Beamwidth
- 360°
- Vertical Beamwidth
- 30° (at 2.4 - 2.483 GHz), 15° (at 5.15 - 5.875 GHz)
- Impedance
- 50 Ohm
Cabling & Wiring
- Connector Provided
- 1 x N-Series connector male
- Limited warranty - 2 years
- -10 °C
- 70 °C
- 0 - 95%
