The ZTE MF93D, second generation ultra-speed 4G (LTE) uFi mobile hotspot device can reach a maximum speed of up to 100 Mbps and can be accessed by 10 users at the same time making it the ideal choice for global users looking to enjoy ultra-speed 4G network services.
Incorporating second generation Qualcomm LTE chips, the ZTE MF93D provides significant performance enhancements to ZTE's first generation LTE uFi products including decreased power consumption and improved heat dispersion. It supports dual-band 2.4 G/5 GHz Wi-Fi networks and mainstream 4G bands in the Europe and Asian-Pacific regions, and can also use 3G and 2G networks, eliminating the cost of upgrading terminals. It has increased battery capacity of 2800 mAh, guarantees that users can enjoy ultra-speed surfing on the Internet regardless of the time or place.
Users' mobile phones can be used to simply and quickly check the status of uFi devices, network signal strength, battery capacity, data flow statistics and upload/download speed.
- ZTE MF93D - mobile hotspot - 4G LTE
- Mobile hotspot - USB 2.0
- Form Factor
- External
- Max Transfer Rate
- 100 Mbps
- Mobile Communication Protocol
- GSM, UMTS, HSDPA, HSPA, HSPA+, LTE
- Mobile Band
- GSM 850/900/1800/1900 / UMTS 850/900/1900/2100 / LTE 800/900/1800/2600
- Networking
- USB, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Battery
- 2800 mAh - up to 9 hrs
- System Requirements
- Apple MacOS, Linux, Microsoft Windows Vista / XP / 7 / 8
- 10.7 cm x 6.08 cm x 1.6 cm
- 123 g
- Mobile hotspot
- Form Factor
- External
- Built-in Devices
- 1.44-inch OLED
Modem
- Bus
- USB 2.0
- Connectivity Technology
- Wireless
- Max Transfer Rate
- 100 Mbps
- Mobile Band
- Wireless
- Data Link Protocol
- IPv6 support, 2T2R MIMO technology
- DLNA CERTIFIED
- Supported Flash Memory Cards
- microSD, microSDHC
- 1 x USB 2.0 , 1 x aerial
- SIM Card Supported
- 1
- Battery
- Lithium Ion
- Capacity
- OS Required
- 10.7 cm
- 6.08 cm
- 1.6 cm
- 123 g
