This versatile product provides a shared ADSL Internet connection for up to 253 computers, game stations, WiFi - enabled phones, and other devices connected wirelessly, via this product's 4 Ethernet LAN ports, or through a switching hub or other network device. Plug the X6's phone cord into a phone line with ADSL service. Then use the X6's built-in wireless capability and/or its 4 Ethernet ports to connect computers, Ethernet switches, HomePlug® adapters, or other devices. Setup is easy using any Web browser. The X6 supports all popular ADSL protocols, and delivers download speeds up to 24 Mbps. Best of all, the X6 is produced and supported by Zoom Telephonics, a communication products leader since 1977.
Optional Use As A Router
If you choose to use the X6's router features, you'll enjoy its flexibility, friendly user interface, and extensive features. The router features are useful for all the computers and other devices plugged directly into the X6, connected to the X6 wirelessly, or linked to the X6 through a switching hub, HomePlug, or other network connection. Extensive X6 router features include WPA2/WPA/WEP wireless security, support for up to 4 SSIDs, WDS, an SPI/NAT firewall, Denial of Service attack protection, IP filtering, Virtual Server, DMZ, LAN and WAN access control, online gaming support, extensive debugging and diagnostic tools, and much more. The friendly X6 graphical user interface makes it easy for you to use your favorite browser to set any router feature you like, even from remote locations.
- Zoom ADSL X6 5690 - wireless router - DSL modem - 802.11b/g - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL2, ADSL2+
- Data Link Protocol
- Ethernet, ATM, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 54 Mbps
- PPTP, L2TP, IPSec, PPPoE, PPPoA, AAL5, IPoA
- Routing Protocol
- RIP-1, RIP-2
- Remote Management Protocol
- SNMP 1, SNMP 2, Telnet, HTTP
- Firewall protection, switching, DHCP support, NAT support, Stateful Packet Inspection (SPI), DoS attack prevention, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, firmware upgradable, Quality of Service (QoS), virtual server support
- IEEE 802.3, IEEE 802.1D, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, UPnP
- Power
- AC 120/230 V (50 - 60 Hz)
- 17.8 cm x 13.7 cm x 3.3 cm
- 1-year warranty
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 54 Mbps
- Routing Protocol
- RIP-1, RIP-2
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2
- Authentication Method
- PAP, CHAP
- IEEE 802.3, IEEE 802.1D, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, UPnP, FCC Part 15 B, FCC Part 68, CS-03, RoHS
- Status Indicators
- Port status, power, WLAN, link/activity
Line Properties
- Framing Format
- ANSI T1.413
Communications
- DSL modem
- ADSL2, ADSL2+
- Protocols & Specifications
- ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.992.3 (G.DMT.bis), ITU G.992.5
- Max Transfer Rate
- 24 Mbps
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , Phone line: 1 x ADSL - RJ-11
Aerial
- Antenna Qty
- 1
- Power Device
- External power adapter
- Voltage Required
- Cables Included
- 1 x network cable , 1 x phone cable
- 17.8 cm
- 13.7 cm
- 3.3 cm
- Limited warranty - 1 year
