Zebra ZXP Series 3 Plastic Card Printer
Quicklinx: C68DWS00 Mfr#: Z32-000C0200EM00
The ZXP series 3 is unique to the card printing market, employing several advanced features that provide high performance at an attractive price. The ZRaster host-based image processing technology takes advantage of the increased processing power of today's PCs to significantly optimize image and print quality while increasing overall print speed throughput. This permits greater sophistication in the image optimizations without sacrificing printer speed or adding extra cost. Zebra high performance ribbons employ an improved chemical formulation specifically designed for fast high-quality image printing, providing more efficient dye transfer and greater durability under high-speed printing conditions.
Zebra ZXP Series 3 - plastic card printer - colour - dye sublimation
Printer Type
Plastic card printer - dye sublimation - colour
5.5 kg
EMEA
Max Media Size
CR-80 Card (85.6 x 54 mm)
Max Media Size (Custom)
85.6 mm x 54 mm
Print Speed
Up to 750 cards/hour - monochrome - CR-80 Card (85.6 x 54 mm) , Up to 180 cards/hour - colour single-sided - CR-80 Card (85.6 x 54 mm) , Up to 180 cards/hour - colour dual-sided - CR-80 Card (85.6 x 54 mm)
Max Resolution (B&W)
300 dpi
Automatic Duplexing
USB, LAN
RAM Installed (Max)
32 MB
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, Interleaved 2 of 5, PDF417, Code 128B, Code 128C
Media Type
Cards, PVC composite card, PVC card
Total Media Capacity
100 cards
Print server
Printer Features
Zebra ZRaster technology
Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista / XP, Microsoft Windows Server 2008
Microsoft Certification
Compatible with Windows 7
20.1 cm x 36.8 cm x 23.6 cm
Printer Type
EMEA
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB, LAN
300 dpi
Automatic Duplexing
Barcodes
Printer Features
RAM
RAM Installed (Max)
32 MB
Media Handling
Media Type
Max Media Size
85.6 mm x 54 mm
Card / Label Sizes
100 cards
Media Feeders
1 x automatic - 100 cards - CR-80 Card (85.6 x 54 mm)
Max Media Capacity
100 cards
Output Trays Capacity
50 cards
Print server
1 x USB - 4 pin USB Type B , 1 x LAN - RJ-45
1 x USB cable
FCC Class A certified
Power adapter
Frequency Required
50/60 Hz
Limited warranty - 2 years , Limited warranty - printhead - 2 years
15 °C
30 °C
20 - 65% (non-condensing)
20.1 cm
36.8 cm
23.6 cm
5.5 kg
