Zebra ZD410 Label Printer
Quicklinx: CS23WS00 Mfr#: ZD41022-D0EM00EZ
If you need fast, dependable printing in space-constrained areas, you need the ZD410. This ultra-compact printer is designed for small work spaces. When it comes to flexibility, the ZD410 shines - this printer creates high-quality labels, receipts, tags and wristbands. This super-fast printer keeps your workers productive. Deployment is a breeze - the ZD410 is loaded with connectivity solutions. The ZD410 is easy to use, operate and troubleshoot, ensuring your printer is always up and running. The ZD410 - the little printer designed with big business functionality.
  • Ultra-compact printer
    The ZD410 is a very small printer, fitting easily in a space-constrained desktop or shelf - you can even mount it on a wall.
  • Excellent connectivity
    The movable media sensor gives you more media possibilities, including die-cut notches or multiple labels across the width. With multiple connectivity technologies, the ZD410 excellently fits into your environment.
  • Easy to use and troubleshoot
    Five status icons - status, pause, data, supplies and network - provide the additional information you need to keep your Zebra printer up, running and available. Users can see if the media needs to be replenished, if the network connection is down and much more.
Zebra ZD410 - label printer - B/W - direct thermal
Printer Type
Label printer - direct thermal - B/W
1 kg
United Kingdom, Europe
Max Media Size
Roll (6 cm)
Print Speed
Up to 152 mm/sec - B/W
Max Resolution (B&W)
203 dpi
USB 2.0, USB host, Bluetooth 4.0
RAM Installed (Max)
256 MB SDRAM
Flash Memory Installed (Max)
512 MB
Language Simulation
ZPL II, EPL2, ZBI
Barcodes
Code 93, Industrial 2 of 5, Code 39, Code 49, CODABLOCK, ISBT 128, QR code, MaxiCode, Aztec code, LOGMARS, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Interleaved 2 of 5, Postnet, PDF417, Data Matrix, PLANET, Plessey, Standard 2 of 5, EAN-8, EAN-13, MSI
Media Type
Receipt paper, tag stock, continuous paper labels, die cut labels, wristband labels, fanfold labels
Black Mark sensor, transmissive media sensor, reflective media sensor, tear bar
11.5 cm x 22 cm x 15.1 cm
Printer Type
Label printer - direct thermal - monochrome
Printer
Print Speed
Up to 152 mm/sec - B/W - 203 dpi
Wireless
203 dpi
Language Simulation
ZPL II, EPL2, ZBI
Fonts Included
16 x bitmapped ZPL II , 2 x scalable ZPL , 5 x expandable EPL2
Barcodes
RAM
RAM Installed (Max)
256 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
512 MB
Media Handling
Media Type
Max Media Size
Roll (6 cm)
Media Sizes
Roll (6 cm)
Max Printing Width
56 mm
Max Printing Length
991 mm
Media Thickness Range
0.08 mm - 0.305 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm, 76.2 mm, 38.1 mm, 12.7 mm, 50.8 mm
Media Feeders
1 x manual - 1 roll - Roll (6 cm)
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
FCC Class B certified, VCCI, C-Tick, BSMI, EN 61000-3-2, ICES-003, NOM, SABS, EN 61000-3-3, EN55024, EN55022 Class B, FCC Part 15.247, CCC, IC, IEC 60950-1, KCC, FCC Part 15.209, S Mark, cTUVus, EN 62311, EN 300 328, BIS, INMETRO, CU, RSS-247, EN 301 893
Power supply
Frequency Required
50/60 Hz
Power Factor Correction
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
4.4 °C
41 °C
10 - 90% (non-condensing)
11.5 cm
22 cm
15.1 cm
1 kg
