The Symbol LS4208 handheld laser scanner delivers exceptional performance in an accesible, intuitive package. Its single-circuit board design ensures sturdiness and an ergonomic shape maximizes user comfort. Continuous one-pass scanning, an innovative multi-line rastering scan pattern, a wide working range and superior motion tolerance make data capture easy, even for novices.
- Symbol LS4208 - barcode scanner
- Barcode scanner - handheld - USB - decoded
- Black
- Localisation
- EMEA
- Minimum Bar Width
- 5 mil
- Scan Element Type
- Visible laser diode
- Connectivity Technology
- Wired
- 6.8 cm x 9.3 cm x 17 cm
- 181 g
- 5-year warranty
- Black
- Localisation
- EMEA
Barcode
- Interface Type
- USB
- Minimum Bar Width
- 5 mil
- Scan Element Type
- Light Source Wave Length
- 650 nm
- Scan Mode
- Single-pass
- Max Working Distance
- 0.7 m
- Pitch (Degrees)
- 60
- Print Contrast Signal (PCS)
- 25%
- Decode Capability
- Code 93, Code 39, UCC/EAN-128, IATA, GS1 DataBar, Bookland, Code 32, Code 39 Full ASCII, Discrete 2 of 5, Codabar, Code 128, UPC, Interleaved 2 of 5, Code 128 Full ASCII, Code 39 Trioptic
- TTL Decoding
- Decoded
- Wired
- 1 x USB
- Included Accessories
- Stand
- Cables Included
- 1 x USB cable - external
- FCC Class B certified, EN 60950, UL 1950, IEC 60950, CSA 22.2 No. 950, EMC, FCC Part 15
- 6.8 cm
- 9.3 cm
- 17 cm
- 181 g
- Limited warranty - 5 years
- 0 °C
- 50 °C
- 5 - 95%
- Drop Specification
- 1.8 m to concrete
