Zebra LS2208 Handheld USB Scanner
Quicklinx: 5862WS00 Mfr#: LS2208-SR20007R-UR
Type: Barcode scanner
Form Factor: Handheld
Max Paper Size: [N/A]
Compatibility: PC
39 In Stock
£44.69 ex VAT
£53.62 inc VAT
Symbol LS2208 Handheld USB Laser Barcode Scanner
  • General Features:
  • 7-footUSB cable
  • USE interface
  • Durable scan element design
  • Fast performance at 100 scans per second
  • Global Trade Item Number (GTlN) Compliant
  • Advanced Data Formatting (ADF) enables users to modify data prior to sending to host computer
  • Universal cables for sharing
  • Bright LED and beeper with adjustable volume
  • Ergonomic design
  • Bi-directional scanner
  • 650 nm visible laser diode light source
  • Durable single-board construction
    Meets stringent 5-ft drop tests.
  • Scratch-resistant tempered glass exit window
    Is designed for continuous use.
  • Accurate first-time capture of 1D bar codes
    Increased productivity, resulting in shorter check-out lines and better customer service.
  • Wide working range
    Delivers optimal performance from contact to 17 in (43 cm).
  • Multiple onboard interfaces
    Simplify installation and integration and ensures future compatibility.
  • Plug-and-Play, with universal cable
    Means rapid deployment, with a single cable connecting to any computing environment.
  • Intuitive design
    Minimizes setup and training time.
  • Ergonomic, lightweight design
    Reduces user fatigue with sleek, balanced form for maximum comfort and productivity.
    Enables users to modify data prior to sending to host computer, reducing costly modifications to the host software.
Symbol LS2208 - barcode scanner
Barcode scanner - handheld - USB - decoded
Twilight black
Scan Element Type
Visible laser diode
Scan Speed
100 scan / sec
Wired
6.3 cm x 8.4 cm x 15.2 cm
146 g
5-year warranty
Twilight black
Barcode
Interface Type
USB
Scan Element Type
Visible laser diode
Light Source Wave Length
650 nm
Scan Mode
Single-pass
Scan Speed
100 scan / sec
Max Working Distance
43 cm
Skew (Degrees)
60
Pitch (Degrees)
65
Print Contrast Signal (PCS)
20%
Decode Capability
EAN/JAN, Code 93, Code 39, UCC/EAN-128, IATA, GS1 DataBar, Code 39 Full ASCII, Discrete 2 of 5, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, MSI-Plessey, Code 128 Full ASCII
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator
1 x USB - Type A
Stand
1 x USB cable - external
VCCI, EN 60950, IEC 950, UL 1950, CSA 22.2 No. 950, ICES-003 Class B, FCC Part 15 B, MITI, EMC, RoHS
6.3 cm
8.4 cm
15.2 cm
146 g
Limited warranty - 5 years
50 °C
5 - 95%
Drop Specification
1.5 m to concrete
Compatibility: PC
Brand: Zebra
