Zebra LP 2824 Plus Label Printer
Quicklinx: 9TTLWS00 Mfr#: 282P-201120-000
The ultra-compact direct thermal LP 2824 Plus bar code label printer brings powerful performance to applications requiring a space-saving printer and media widths of 2.2 inches/56 mm or less. It includes a 32-bit RISC processor for faster formatting and first label out, an auto-sensing serial port, and co-resident EPL and ZPL programming languages.
The LP 2824 Plus is easy to use with an OpenAccess design and clear media window for simple media loading and monitoring, color-coded user-guide touch points, and instant reset button. Serial, Parallel, and USB interfaces, plus networking option, ensure easy system integration for a wide range of applications.
  • A powerful, ultra-compact printer
    One of the smallest in its class, the easy-to-use 2824 Plus desktop printer tucks into your tightest work spaces and prints 2-inch-wide labels or receipts with best-in-class print speeds. The 2824 Plus includes Zebra setup utilities, which guides you through simple setup steps so you can get up and running quickly. It also includes an OpenAccess design and clear media window for simple media loading and monitoring.
  • Better performance, more flexibility
    A robust 32-bit RISC processor increases throughput and productivity with faster formatting and first label out. For greater flexibility and enhanced performance, choose from a variety of options like convenient peeler and cutter, and massive flash memory that lets you store and use more graphics and fonts. With co-resident EPL and ZPL programming languages, the 2824 Plus works seamlessly with other Zebra printers, while Serial/Parallel/USB connectivity allows easy system integration.
Zebra LP 2824 Plus - label printer - B/W - direct thermal
Printer Type
Label printer - direct thermal - B/W
1.2 kg
Max Media Size
Roll (6 cm)
Max Media Size (Custom)
60 mm
Print Speed
Up to 102 mm/sec - max speed
Max Resolution (B&W)
203 dpi
USB, serial
RAM Installed (Max)
8 MB
Flash Memory Installed (Max)
4 MB
Language Simulation
ZPL, ZPL II, EPL2, EPL
Barcodes
Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, CODABLOCK, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Japanese Post, Code 128B, Code 128C, German Post, MSI-3, Code 128A, GS1 DataBar Omnidirectional
Media Type
Labels, continuous forms, perforated thermal paper, receipt paper, linerless labels, fanfold paper, tag stock
Microsoft Certification
Compatible with Windows 7
11.1 cm x 21.6 cm x 17.1 cm
Printer Type
Label printer - direct thermal - monochrome
Printer
Print Speed
Up to 102 mm/sec - max speed - 203 dpi
Wired
USB, serial
203 dpi
Language Simulation
Barcodes
RAM
RAM Installed (Max)
8 MB
Flash Memory
Flash Memory
4 MB
Media Handling
Media Type
Max Media Size
Roll (6 cm)
60 mm
Media Sizes
Roll (6 cm)
Max Printing Width
56 mm
Max Printing Length
991 mm
Media Thickness Range
0.08 mm - 0.18 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm, 38 mm
Media Feeders
1 x manual - 1 roll - Roll (6 cm)
1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B
UL, VCCI, C-Tick, NOM, FCC, IRAM
Power adapter - external
Frequency Required
50/60 Hz
Software Included
Drivers & Utilities, ZebraDesigner
5 °C
41 °C
10 - 90%
11.1 cm
21.6 cm
17.1 cm
1.2 kg
Weight (Shipping)
2.4 kg
