Zebra's complete and integrated wristband solution combines the small-footprint HC100 thermal printer with easy-to load cartridges containing Zebra's patent pending antimicrobial - Z-band direct wristbands. Its smart technology senses the wristband type and auto calibrates the settings for optimized print quality.
The design of the HC100 provides easy-to-use features that require minimal, if any, user interaction. There is minimal training required to use the HC100 or to load or switch the cartridge - it's a quick and simple task.
The HC100 printer is designed for wristband printing. Administrators can quickly process patient admissions without having to change the media in the printer. It also eliminates waste by printing only the required number of wristbands.
- Zebra HC100 - label printer - B/W - direct thermal
- Printer Type
- Label printer - direct thermal - B/W
- 1.4 kg
- Max Media Size
- Roll (3.02 cm)
- Print Speed
- Up to 102 mm/sec - max speed - Roll (3.02 cm)
- Max Resolution (B&W)
- 300 dpi
- Interface
- USB, serial
- RAM Installed (Max)
- 16 MB SDRAM
- Flash Memory Installed (Max)
- 8 MB
- Language Simulation
- ZPL, ZPL II, Extensible Mark-up Language (XML)
- Barcodes
- Code 93, Industrial 2 of 5, Code 39, Code 49, CODABLOCK, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Code 2 of 5, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Plessey
- Media Type
- Labels
- Microsoft Certification
- Compatible with Windows 7
- 12.7 cm x 24.2 cm x 17.8 cm
- Printer Type
- Label printer - direct thermal - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB, serial
- 300 dpi
- Fonts Included
- 16 x bitmapped , 1 x scalable
- Barcodes
RAM
- 16 MB
- Technology / Form Factor
- SDRAM
Flash Memory
- Flash Memory
- 8 MB
Media Handling
- Media Type
- Labels
- Max Media Size
- Roll (3.02 cm)
- Media Sizes
- Roll (3.02 cm), Roll (2.54 cm), Roll (1.91 cm)
- Max Printing Length
- 558 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (3.02 cm)
- Connections
- 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B
- TUV, VCCI, C-Tick, EN55024, EN55022 Class B, CB, FCC Part 15 B, IEC 60950-1, IEC 60601-1
- Power Device
- Power adapter - external
- Frequency Required
- 50/60 Hz
- Power Factor Correction
- Software Included
- Drivers & Utilities, ZebraDesigner, ZebraNet Utilities 7.0
- 5 °C
- 40 °C
- 20 - 85% (non-condensing)
- 12.7 cm
- 24.2 cm
- 17.8 cm
- 1.4 kg
