In the mission-critical world of healthcare, caregivers need to be able to accurately capture virtually any bar code, on any medium, in any condition - with first-time every time predictability. And with the DS4308-HC on your workstations-on-wheels and other carts, they can. The DS4308-HC does it all - 1D or 2D, electronic or printed on paper labels, tiny dense codes on the curved surface of a vial, codes printed on reflective surfaces like IV bags, codes under shrink wrap on doses of medication - and even smudged, scratched or poorly printed bar codes. The result? The priceless peace of mind that the right patient received the right medication and the right test results, every time.
PRZM Intelligent Imaging technology for next generation performance
Resets the bar for 2D imaging by improving decode performance and snappiness, ensuring the virtually instant capture of bar codes required in the mission critical world of healthcare. -
Megapixel sensor for maximum data capture flexibility
Give your healthcare workers true peace of mind with the ability to scan virtually any 1D, 2D or PDF417 bar code, as well as the many challenging bar codes in healthcare - including the tiny dense codes wrapped around the curved surface of a vial to bar codes that are stained or smudged. -
Largest "sweet spot" for can't-miss point-and-shoot scanning simplicity
A decode range allows healthcare workers to scan any bar code type at any density nearer and farther than any other scanners in its class, making scanning truly second nature. And with omni-directional scanning, healthcare workers never need to waste valuable time aligning bar code and scanner. -
Withstands constant disinfecting
IP42 sealing and a specially designed disinfectant-ready plastic housing allow safe wipe-down with a wide variety of harsh chemicals to help prevent the spread of germs. -
Unsurpassed aiming technology
The crisp and bright aiming dot has the reach and brightness needed to ensure the fast capture of data. -
Durable design for superior uptime
Built to survive a 6 ft./1.83 m drop to concrete, the DS4308-HC delivers reliable operation, despite the inevitable everyday drops. -
Day and night 'do-not-disturb' modes
Healthcare workers can choose to mix and match the decode feedback that is right for the moment: visual (green light/ red light), haptic (vibration) and an audible tone. -
Superior out-of-box experience
The DS4308-HC is up and running almost instantly. Smart auto-host detect cables automatically determine which interface is attached, eliminating the need to scan numerous configuration bar codes. -
Easy on the eyes
Thanks to a special LED wavelength and recessed lighting, when a bar code is scanned, the light that is emitted is soft and unobtrusive, preventing eye fatigue and improving the environment for patients and healthcare workers.
- Symbol DS4308-HC - barcode scanner
- Barcode scanner - handheld - interface cable required - decoded
- Nova white
- Minimum Bar Width
- 3 mil
- Scan Element Type
- 2D imager
- Connectivity Technology
- Wired
- 6.7 cm x 9.8 cm x 16.5 cm
- 162 g
- 5-year warranty
- Nova white
Barcode
- Interface Type
- Interface cable required
- Minimum Bar Width
- 3 mil
- Scan Element Type
- 2D imager
- Light Source Wave Length
- 617 nm
- Max Working Distance
- 71.1 cm
- Skew (Degrees)
- 60
- Pitch (Degrees)
- 65
- Print Contrast Signal (PCS)
- 20%
- Decode Capability
- EAN/JAN, Code 93, Matrix 2 of 5, Code 39, UCC/EAN-128, ISBT 128, GS1 DataBar, QR code, MaxiCode, Aztec code, Bookland, Code 32, Code 39 Full ASCII, Discrete 2 of 5, MicroPDF417, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, PLANET, TLC39, Australian Post, Canadian Post, China Post, Japanese Post, Kix (Netherlands) Post, Korea Post, EAN-UCC Composite, ISSN, Code 39 Trioptic, UK Post, Royal Mail, Micro QR code, China Han Xin Code
- TTL Decoding
- Decoded
- Wired
- OK Notification
- Beeper
- PRZM Intelligent Imaging technology
- EN55024, EN55022 Class B, ICES-003 Class B, FCC Part 15 B, UL 60950-1 Second Edition, EN 60601-1-2, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, RoHS 2011/65/EU, IEC 62471:2006, EN 62471:2008
- 6.7 cm
- 9.8 cm
- 16.5 cm
- 162 g
- Limited warranty - 5 years
- 0 °C
- 50 °C
- 5 - 95% (non-condensing)
- Drop Specification
- 1.8 m to concrete
