The ZM-VE500 provides and advanced solution to connect a SATA device to a USB 3.0 host with an integrated 32-bit microprocessor and embedded SRAM. To provide a high performance with a real-time hardware encryption based on AES256bit architecture. Through virtual drive technology is available in one off external hard disk drive solutions.
- ZALMAN ZM-VE500 - storage enclosure - SATA 6Gb/s - USB 3.0
- Storage enclosure - external
- Bus Type
- USB 3.0
- Silver
- Expansion Bays
- 1 x internal - 2.5"
- Hard Drive Form Factor Compatibility
- 2.5"
- Interface
- SATA 6Gb/s
- Supported Devices
- Hard drive, solid state drive
- Product Material
- Polycarbonate, acryl, aluminium alloy
- Power Source
- USB bus
- System Requirements
- Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/8.1/10
- 8.08 cm x 14.6 cm x 1.4 cm
- 91 g
- 2.5"
- Host Bus
- USB 3.0
- Product Material
- Silver
Storage Controller
- Interface
- SATA 6Gb/s
- Supported Devices
- Bays
- 1 x USB 3.0 - Micro-USB Type B
- Connections
- 1 x USB 3.0 - 9 pin USB Type A
- Included Accessories
- Pouch
- Cables Included
- 1 x USB 3.0 cable - external
- Status LCD display, password security, virtual ODD function mode, touchpad
- Mounting Kit
- Included
- AES-256
- Power Source
- USB bus
- OS Required
- 8.08 cm
- 14.6 cm
- 1.4 cm
- 91 g
