It is features blue LED water block, the blue LED not only provides molding effect, but also allows user to check on the pump.
Built-in ultra quiet/ high efficient water block, minimized tube connection help coolant to rotate fast and stable.
Blue LED water block
Blue LED not only provides molding effect, but also allows user to check on the pump. -
Built-in pump within water block
Built-in ultra quiet/ high efficient water block, minimized tube connection help coolant to rotate fast and stable. -
Slim water block design
Slim water block allows to be installed into ATX case an also slim and LP (Low Profile) cases. -
Micro fins and copper base
High cooling performance with pure copper water block and inner pure copper micro fins through efficient heat transfer. -
Zalman high quality design
Zalman unique hairline process covers for upgraded design.
- ZALMAN LQ SERIES LQ315 - processor liquid cooling system
- Product Type
- Processor liquid cooling system
- Compatibility
- LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2
- Heatsink Material
- Copper
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Long Life Bearing
- Rotation Speed
- 900-2000 rpm
- Power Connector
- 3-pin plug, 4-pin fan connector
- Rated Voltage
- 12 V
- Blue LEDs, Pulse-width modulation (PWM) support
- 575 g
- Product Type
- 575 g
Heatsink & Fan
- Compatible With
- Processor Compatibility
- Core i7 Extreme Edition - all speeds , Core i7 - all speeds , Core i5 - all speeds , Core i3 - all speeds , Pentium - all speeds , Celeron - all speeds , Phenom II - all speeds , Athlon II - all speeds , Opteron - all speeds , Phenom - all speeds , Athlon X2 - all speeds , Athlon - all speeds , Sempron - all speeds , FX Series - all speeds
- Heatsink Material
- Copper
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Long Life Bearing
- Rotation Speed
- 900-2000 rpm
- Power Connector
- Rated Voltage
- 12 V
- Mounting Kit
- Included
