Three heatpipes and aluminum fins are designed for maximum cooling while cooler setup quickly expels hot air out of the case.
An ultra quiet 92 mm fan with FSB bearing is incorporated for minimized noise and excellent cooling.
Compatible with Intel LGA1155/1156/775 and AMD FM1/AM3+/AM3/AM2+/AM2/939/940/754
Powerful cooling performance
Three heatpipes and aluminum fins are designed for maximum cooling while cooler setup quickly expels hot air out of the case. -
Ultra quiet 92 mm fluid shield bearing fan
An ultra quiet 92 mm fan with FSB bearing is incorporated for minimized noise and excellent cooling. -
PWM fan control
The PWM (Pulse Width Modulation) fan automatically adjusts fan speed (RPM) according to the CPU's temperature. -
Easy installation
The cooler is designed with tool-less installation clip, making installation convenient.
- ZALMAN CNPS-5X Performa - processor cooler
- Product Type
- Processor cooler
- Package Content
- Thermal paste
- Compatibility
- Socket 754, Socket 940, LGA775 Socket, Socket 939, LGA1156 Socket, Socket AM2, Socket AM2+, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, LGA1150 Socket, Socket FM2
- Heatsink Material
- Aluminium and copper
- Fan Diameter
- 92 mm
- Fan Bearing
- Fluid Shield Bearing
- Rotation Speed
- 1400-2800 rpm
- Noise Level
- 20 - 32 dBA
- Rated Voltage
- 12 V
- Pulse-width modulation (PWM) support, 6 copper heatpipes
- 6.4 cm x 12.7 cm x 13.4 cm
- 320 g
- Product Type
- Processor cooler
- Package Content
- Thermal paste
- 6.4 cm
- 12.7 cm
- 13.4 cm
- 320 g
Heatsink & Fan
- Compatible With
- Processor Compatibility
- Core 2 Duo - all speeds , Pentium 4 - all speeds , Celeron D - all speeds , Pentium D - all speeds , Core 2 Quad - all speeds , Core 2 Extreme - all speeds , Pentium Dual Core - all speeds , Core i7 - all speeds , Core i5 - all speeds , Core i3 - all speeds , Core i7 Extreme Edition - all speeds , Sempron - all speeds , Athlon - all speeds , Athlon 64 FX - all speeds , Opteron - all speeds , Phenom - all speeds , Athlon X2 - all speeds , Phenom II - all speeds , Athlon II - all speeds , AMD A Series - all speeds , FX Series - all speeds
- Heatsink Material
- Heatsink Dimensions
- 134 mm x 127 mm x 64 mm
- Fan Diameter
- 92 mm
- Fan Bearing
- Rotation Speed
- 1400-2800 rpm
- Noise Level
- 20 - 32 dBA
- Rated Voltage
- 12 V
- Mounting Kit
- Included
