Zalman CNPS10X Performa Ultra-Quiet CPU Cooler
Quicklinx: 859BWS00 Mfr#: CNPS10X PERFORMA
Optimally designed aluminum fins disperse heat away from the CPU via 5 heatpipes, while switching noise free, high capacity 120mm fan quickly cools the heatsink for stable operation of high performance CPUs.
Differentiated from typical U-shaped heatpipe coolers, a central band of rippled aluminum fins adds a sleek and cool aesthetic finish.
Powerful Cooling Performance
Optimally designed aluminum fins disperse heat away from the CPU via 5 heatpipes, while switching noise free, high capacity 120mm fan quickly cools the heatsink for stable operation of high performance CPUs. Switching Noise' is the high frequency harmonic noise that can result from voltage regulation.
Dual Fan Support
The heatsink is designed to mount one or two fans according to the users preferences.
Differentiated Design
Versatile Compatibility
The CNPS10X Performa accommodates a broad range of sockets. Compatible with Intel LGA2011/1366/1155/1156/775 and AMD FM1/AM3+/AM3/AM2+/AM2. LGA2011 Compatibility with ZM-CS2011.
180mm Wide Case Compatibility
For optimum case compatibility the heatsink's height is set to 152mm which ensures compatibility with case width of 180mm or greater.
High Performance Super Thermal Grease ZM-STG2M
The high performance super thermal grease ZM-STG2M maximizes heat transfer from the CPU to the base of CNPS10X Performa for intensified cooling performance.
PWM Fan Speed Resistor
When connected to the resistor cable (RC24P), the input voltage of the PWM Fan can be adjusted to control the fan speed and noise level according to user preference. Quiet Mode (RC24P Connected): 900~1,350RPM / 17~24dBA ±10% / Performance Mode (RC24P Not Connected): 900~2,000RPM / 17~36dBA ±10%
  • Dimensions 132(L) x 100(W) x 152(H)mm
  • Weight 748g
  • Materials Fins: Aluminum / Base: Copper
  • Dissipation Area 7,900?
  • Heatpipes 5 U-shaped heatpipes
  • Fan PWM 120mm Fan
  • Fan Dimensions 120(L) x 120(W) x 25(H)mm
  • Fan RPM 900 ~ 1,350 ± 10% (RC24P Connected), 900 ~ 2,000 ± 10% (RC24P Not Connected)
  • Noise 17 ~ 24dBA ± 10% (RC24P Connected), 17 ~ 36dBA ± 10% (RC24P Not Connected)
  • Fan Bearing Long life bearing
  • Fan Speed Adjustment PWM & VR
  • Connector 4-Pin
  • Fan Controller VR Fan Control (RC24P)
  • PWM Duty Cycle 30 ~ 100 ± 5%
  • Rated Voltage 12V
*this will require an adapter to fit.
  • Powerful cooling performance
  • Differentiated design
  • 180mm wide case compatibility
  • PWM fan speed resistor
    When connected to the resistor cable, the input voltage of the PWM fan can be adjusted to control the fan speed and noise level according to user preference.
ZALMAN CNPS-10X Performa - processor cooler
Processor cooler
Package Content
Thermal paste
Grey
Compatibility
Socket 754, Socket 940, LGA775 Socket, Socket 939, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3
Heatsink Material
Aluminium with copper base
Fan Diameter
120 mm
Fan Bearing
Long Life Bearing
Power Connector
4-pin fan connector
Product Material
Aluminium, brass
10 cm x 13.2 cm x 15.2 cm
0.75 kg
Processor cooler
Product Material
Aluminium, brass
Package Content
Thermal paste
10 cm
13.2 cm
15.2 cm
0.75 kg
Grey
Heatsink & Fan
Compatible With
Processor Compatibility
Core i7 - all speeds , Core i5 - all speeds , Core i3 - all speeds , Core 2 Quad - all speeds , Core 2 Duo - all speeds , Core 2 Extreme - all speeds , Pentium Dual Core - all speeds , Pentium D - all speeds , Pentium 4 - all speeds , Celeron D - all speeds , Phenom II - all speeds , Athlon II - all speeds , Phenom - all speeds , Athlon X2 - all speeds , Athlon - all speeds , Sempron - all speeds , Dual-Core Opteron - all speeds , Opteron - all speeds
Heatsink Material
Fan Diameter
120 mm
Fan Bearing
Long Life Bearing
Power Connector
4-pin fan connector
-40 °C
150 °C
