The Yale Door/Window Contact is wireless and easy to pair with your Yale Home Alarm System*, allowing you to extend you system to tailor it to your individual needs.
This accessory will activate the alarm when a door or window its connected to is opened.
*Compatible with Yale SR- Smart Home Alarm Systems and EF- Series Alarms.
868MHz Technology - Yale uses a frequency that is tightly controlled, meaning a clearer channel with less interference.
Connected - Connect to Yale SR Smart Home Alarm and EF Series Alarm Kits.
DIY Friendly - Wireless & easy to pair with your Yale Home Alarm System*.
2 Year Guarantee - Guaranteed for 2 years from date of purchase.
Batteries Included
- Yale Easy Fit EF-DC - door and window sensor
- Product Type
- Door and window sensor
- Power Source
- Battery
- Connectivity
- Wireless
- Frequency Band
- 868 MHz
- 2-year warranty
- Product Type
- Power Source
- Battery
- Connectivity Technology
- Wireless
- Frequency Band
- 868 MHz
- Form Factor
- CR2032
- Battery Included
- Required Qty
- 1
- Included Accessories
- Mounting kit
- Warranty
- 2-year warranty
- RoHS, WEEE
- -10 °C
- 40 °C
- 0 - 65%
