Y-cam YCW004 CMOS Low Light Mode Box Camera
Quicklinx: 7XFTWS00 Mfr#: YCW004
Due to the unique way the Y-cam has been designed, you no longer have to be "tech-savvy" to install and use IP Video Cameras. The user-friendly installation procedure and intuitive web-based interface allows you to easily connect to your camera whenever and from wherever you wish.
The Y-cam produces video at a maximum frame rate of 30fps displayed at up to 640 x 480 resolution, therefore allowing clear and smooth images to be viewed. The frame rate automatically adjusts to the available bandwidth.
The Y-cam White S can be wall-mounted, ceiling-mounted or placed on a flat surface using the supplied camera stand.
  • Quick and simple setup
    Due to the unique way the Y-cam has been designed, you no longer have to be "tech-savvy" to install and use IP video cameras. The user-friendly installation procedure and intuitive web-based interface allows you to easily connect to your camera whenever and from wherever you wish.
  • High quality video with sound
  • Motion detection alerts via email
    The Y-cam comes with useful alarm tools that will keep you notified if any motion is detected. It has built-in functions that can generate alarm triggers via email and by uploading images straight to a website. Unlike conventional activity detection, the Y-cam uses vector information to detect motion, therefore achieving better reliability against false alarms.
  • Monitor and record live video and audio from anywhere
    You can view live video with sound from virtually anywhere in the world as long as you have a computer, a web browser and an Internet connection. With the simple push of a button, you can take snapshots and record video directly onto your computer's hard drive.
  • Full Macintosh compatibility
    The Y-cam S range is fully compatible with the Apple Macintosh and its associated devices. Mac users can now view live video with audio, control the motion detection settings within a browser (using Adobe Flash), take snapshots from the live feed, and also record footage locally using QuickTime Pro.
  • MPEG-4 compression for reduced bandwidth and storage
    Unlike many cheaper models in the market, the Y-cam utilizes the MPEG-4 compression format. This is a valuable chipset that achieves high compression ratios, allowing smooth moving images to be streamed over lower bandwidth connections.
  • Mobile viewing
    With support for MJPEG and 3GPP the camera provides a live view for multiple platforms, including Apple Macs, and mobile devices including the iPhone and Blackberry. The Y-cam's live stream can be viewed using any mobile phone that can play VLC-compatible streams.
  • Multi-client access and password protection
    The Y-cam supports up to 16 simultaneous remote users. This allows easy and efficient video conferencing with minimum setup. Password protection also ensures no one able to access the cameras without authorization.
  • Secured wireless connectivity
    The Y-cam can connect directly to a network or the Internet, either over Wireless (802.11b/g) networking, or over 10/100 with the supplied network cable. The Y-cam utilizes encryption methods such as WEP, and even the more powerful WPA and WPA2, so you can be sure your camera will only be accessed by authorized users.
  • Compact design
Y-cam White S - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in microphone
8.5 cm x 3 cm x 8.5 cm
150 g
Wired, wireless
Camera
Max Resolution
640 x 480
Frame Rate (max)
30 frames per second
Optical Sensor Type
CMOS - 1/4" - 0.31 MP
Lens Iris
F/2.0
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g
1 - network cable
Voltage
DC 5 V
Motion sensor, auto exposure control, auto gain control, auto white balance
Environmental Parameters (operating)
-5 °C - 45 °C; 20 - 80% (non-condensing) relative humidity
Audio Support
Wired, wireless
8.5 cm
3 cm
8.5 cm
150 g
Camera
Colour - fixed
Digital Video Format
MPEG-4, MJPEG, ASF, 3GPP
Max Digital Video Resolution
640 x 480
Video Capture
640 x 480 @ 30 fps
Still Image Capture Resolution
640 x 480
Image Sensor
0.31 MP CMOS 1/4"
Lens Construction
Lens Iris
F/2.0
Horizontal Field of View (degree)
53.4
Vertical Field of View (degree)
40
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, UPnP, RTCP, PPPoE
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
Stand
1 x network cable
Power Requirements
DC 5 V
Power adapter - external 3.25 Watt
Software Included
Drivers & Utilities
-5 °C
45 °C
Relative Humidity (operating)
