Y-cam IP Camera Wifi LAN Black
Quicklinx: 6MCYWS00 Mfr#: YCB002
The Y-cam Black utilizes 30 infrared LEDs to provide high levels of "invisible" light in dark environments. The intelligent photosensitive components can automatically turn on the LEDs in low light conditions or the user can select "moonlight view" which superimposes frames together to increase brightness.
  • Infrared night vision
  • Quick and simple setup
    Due to the unique way the Y-cam has been designed, you no longer have to be "tech-savvy" to install and use IP Video Cameras. The user-friendly installation procedure and intuitive web-based interface allows you to easily connect to your camera whenever and from wherever you wish.
  • High quality video with sound
    The Y-cam produces video at a maximum frame rate of 30fps displayed at up to 640 x 480 resolution, therefore allowing clear and smooth images to be viewed. The frame rate automatically adjusts to the available bandwidth.
  • Motion detection alerts via email
    The Y-cam comes with useful alarm tools that will keep you notified if any motion is detected. It has built-in functions that can generate alarm triggers via email and by uploading images straight to a website. Unlike conventional activity detection, the Y-cam uses vector information to detect motion, therefore achieving better reliability against false alarms.
  • Monitor and record live video and audio from anywhere
    You can view live video with sound from virtually anywhere in the world as long as you have a computer running Internet Explorer and an Internet connection. With the simple push of a button, you can take snapshots and record video directly onto your computer's hard drive.
  • MPEG-4 compression for reduced bandwidth and storage
    Unlike many cheaper models in the market, the Y-cam utilizes the MPEG-4 compression format. This is a valuable chipset that achieves high compression ratios, allowing smooth moving images to be streamed over lower bandwidth connections.
  • Mobile viewing
    With support for MJPEG and 3GPP the camera will provide a live view from multiple platforms including Apple Macs and mobile devices including the iPhone. The Y-cam Black live stream can be viewed using a mobile phone running VLC players like RealPlayer and Quicktime.
  • Multi-client access and password protection
    The Y-cam supports up to 16 simultaneous remote users. This allows easy and efficient video conferencing with minimum setup. Password protection also ensures no one able to access the cameras without authorization.
  • Secured wireless connectivity
    The Y-cam can connect directly to a network or the Internet, either over wireless (802.11b/g) networking, or over 10/100 with the supplied network cable. The Y-cam utilizes encryption methods such as WEP, and even the more powerful WPA and WPA2, so you can be sure your camera will only be accessed by authorized users.
  • Compact design
    The Y-cam Black can be wall-mounted, ceiling-mounted or placed on a flat surface using the supplied camera stand.
Y-cam Black - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in microphone
8.5 cm x 3 cm x 8.5 cm
150 g
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
640 x 480
Frame Rate (max)
30 frames per second
Optical Sensor Type
CMOS - 1/4" - 0.31 MP
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g
Voltage
DC 5 V
Motion sensor, auto exposure control, auto gain control, auto white balance
Environmental Parameters (operating)
-15 °C - 45 °C; 20 - 95% relative humidity
Audio Support
Wired, wireless
8.5 cm
3 cm
8.5 cm
150 g
Camera
Colour - Day&Night - fixed
Digital Video Format
MPEG-4, MJPEG
Max Digital Video Resolution
640 x 480
Infrared LEDs
30
Video Capture
640 x 480 @ 30 fps
Supported Image Formats
JPEG
Still Image Capture Resolution
640 x 480, 320 x 240, 160 x 120
Image Sensor
0.31 MP CMOS 1/4"
Lens Construction
Horizontal Field of View (degree)
60
Vertical Field of View (degree)
45
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, PPPoE
Interfaces Details
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
Stand
Power Requirements
DC 5 V
Power adapter - external 3.75 Watt
Software Included
Drivers & Utilities
Microsoft Windows Vista / 2000 / XP
System Requirements Details
Windows 2000/XP/Vista - Pentium III - 800 MHz - RAM 128 MB
-15 °C
45 °C
Relative Humidity (operating)
20 - 95%
