XIGMATEK XLF-F8253 LED Fan
Quicklinx: 77QBWS00 Mfr#: XLF-F8253
This cooling fan catches not only your eyes, but it also performs adding more airflow in your PC case. It comes with max 2200 RPM and 29.2 CFM and also with quite level. Shinning LED light and transparent colorific frame/blade make your PC case a spotlight. To make your PC case a spotlight and outstanding performance, XLF-F8253 is the optimal choice.
XIGMATEK XLF-F8253 - case fan
Case fan
Fan Diameter
80 mm
Fan Height
25 mm
Fan Bearing
Long Life Bearing
Rotation Speed
2200 rpm
Air Flow
29.2 cfm
Power Connector
3-pin plug, 4 pin Molex connector
White LED x4
8 cm x 8 cm x 2.5 cm
Case fan
8 cm
8 cm
2.5 cm
Heatsink & Fan
Fan Diameter
80 mm
Fan Height
25 mm
Fan Bearing
Long Life Bearing
Rotation Speed
2200 rpm
Air Flow
29.2 cfm
Power Connector
White LED x4
Mounting Kit
Included
Sound Emission
25 dBA
