XIGMATEK Prime SD1484 Silent Gaming Cooling System
Quicklinx: 865NWS00 Mfr#: CAC-SYHH4-U01
An outstanding performance air cooler, Prime SD1484 creates most efficient heat conduction and imbalance heat-pipe arrangement to provide dissipating surface and cooling performance. Prime SD1484 combines 140mm PWM fan, rubber fan clip, 4pcs F8 heat-pipe, supports multiple-platforms, and can be used on Socket 1366/ 1155/ 1156/ 775/ 2011 platform, and AM2/ AM3/ FM1 Socket.
  • H.D.T (Heat-pipe Direct Touch) technology
  • Patent Blade-Fin technology increases 20% of ventilation and drops 10% noise
  • Patent Blade-Fin technology is good at the prevention of keeping dust away the fins edge
  • Special fins (T: 0.5mm) style combination provides efficient air flow
  • Unique & Patent Anti-vibration rubber fastens prevent vibration and absorb noise
  • Dual fans installed option, 140mm or 120mm
  • Equipped with multiple clips to support Intel LGA1366/1156/1155/775 and AMD AM3/AM2+/AM2
  • 2 Years Manufacturers Warranty
Specifcations
  • Product Name: Prime SD1484
  • Product Number: CAC-SYHH4-U01
  • Dimension: 145(W) x 60(D) x 159(H) mm
  • Heat Sink: Base Material H.D.T. (Heat-pipes Direct Touch), Fin Material Aluminum Alloy
  • Heat-pipe: SPEC F8mm, Q´ty 4pcs
  • Fan: Dimension 140(W) x 140(H) x 25(D) mm, Voltage Rating 12V, Starting Voltage 9V, Speed 800~1200 R.P.M., Bearing Type Sleeve Bearing(with copper axle), Air Flow 90.3 CFM (Max.), Air Pressure 1.08 mmH2O (Max.), Life Expectance 40,000 hrs, Noise Level 18dBA (Max.), Connector 4 pin with PWM, Q´ty 2pcs
  • Weight: 710g (Heat Sink Only)
  • Thermal Resistance: 0.14 ?/W
  • Warranty: 2 Years Manufactures Warranty
XIGMATEK Prime SD1484 - processor cooler
Processor cooler
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket
Heatsink Material
Aluminium
Fan Diameter
140 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
800-1200 rpm
Air Flow
90.3 cfm
Noise Level
18 dBA
Power Connector
3-pin plug, 4-pin fan connector
Rated Voltage
12 V
Heat-pipe Direct Touch (H.D.T.) Technology, 4 copper heatpipes (8 mm)
14.5 cm x 6 cm x 15.9 cm
Processor cooler
14.5 cm
6 cm
15.9 cm
Heatsink & Fan
Compatible With
Processor Compatibility
Core i3 , Core i5 , Core i7
Heatsink Material
Aluminium
Thermal Resistance
0.14 °C/W
Fan Diameter
140 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
800-1200 rpm
Air Flow
90.3 cfm
Air Pressure
1.08 mm
Noise Level
18 dBA
Power Connector
Rated Voltage
12 V
Start Voltage
9 V
