NRP-PC502, the XIGMATEK high efficiency and eco-friendly power supply not only boots up your PC but makes efforts for our mother Earth. NRP-PC502 is the first XIGMATEK 80Plus Bronze certified power supply up to 85% AC-DC switching efficiency with 0.99 active PF rate. If you use NRP-PC502 in your system, you can reduce energy waste, thermal release, your wallet, and CO2 emission, save trees for our Earth. When you are playing games, surfing internet, watching videos, you are saving our green world for your kids.
High efficiency over 85%
Higher efficiency, lower energy loss, cooler our Earth. -
Compliant with ATX12V Ver. 2.3
Compliant with Intel ATX12V Ver. 2.3 PSU design guide. -
0.99 active PFC rate
The highest AC utility rate and active switch for universal AC voltage. -
Real and stable 500W output
Continuous 500W total DC output for real 100% loading. -
DC quality with low ripple noise
Low ripple noise DC output for better devices performance. -
Dual 12V output rail
Compliant with ATX12V requirement and support 240VA safety. -
140mm silent cooling fan
The bigger fan is equal to lower RPM and less noise. -
Smart thermal fan control
Fan RPM was controlled by temperature and keep silence in typical loading. -
All DC cables with mesh sleeve
Reduce airflow resistance for better thermal release in PC case. -
PCIe graphic card connector support
Support high-end graphic card with PCIe 6/8pin connector.
- XIGMATEK NRP-PC502 - power supply - 500 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.3
- 80 PLUS Certification
- 80 PLUS Bronze
- Input Voltage
- AC 115/230 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 500 Watt
- Output Current
- +3.3V - 24 A / 0.5 A , +5V - 15 A / 0.2 A , +12V1 - 20 A / 0.5 A , +12V2 - 20 A / 1 A , -12V - 0.3 A / 0 A , +5VSB - 2.5 A / 0.05 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x 4 PIN internal power , 4 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector , 1 x 6 pin PCI Express power , 1 x 8 pin PCI Express power with detachable 2 pin section , 1 x power 8 pin +12V with detachable 4 pin section
- Cooling System
- 140 mm fan
- Black
- 15 cm x 16 cm x 8.6 cm
- ATX12V 2.3
- PSU Form Factor
- ATX
- Black
- Input Voltage
- AC 115/230 V
- Input Voltage Range
- AC 100 - 240 V
- Frequency Required
- 47/63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 500 Watt
- Output Current
- 80 PLUS Bronze
- MTBF
- 100,000 hours
- Cooling System
- 140 mm fan
- Fan speed monitoring, overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, dual 12V rails, short-circuit protection, non-modular
- TUV, FCC, RoHS, WEEE
- 10 °C
- 40 °C
- 20 - 90%
- Sound Emission
- 16 dBA
- 15 cm
- 16 cm
- 8.6 cm
